Ellipsoid Headlights Not Fitting
  • MB07
    • Jan 2018
    • 62
    I went to a pick and pull and found a pair of ellipsoid headlights for cheap. I get them back home and try to install them on my 1987 and the plastic bracket on the headlights seems to be too big. When I try to fit them in, it gets stuck on either the valance tab or the radiator support.
    I can either trim the plastic bracket in hopes to get it to fit but possibly weakening its structural integrity. Or modify the existing sealed beam metal bracket to fit the ellipsoid bulbs.
    Has anyone else had this issue?
    2009 BMW 328i xDrive (Daily/winter drift king)
    1987 BMW 325i (Currently torn apart)
    Instgram: @Ebola.30
  • earthwormjim
    • Jul 2014
    • 434
    Do you have the right and left sides reversed, meaning the lights are upside down?
    • MB07
      • Jan 2018
      • 62
      I do not. The screw holes wouldn’t line up if I have them upside down. Plus I marked them when I pulled them from the 88 vert at the junk yard. I’ll take some pics tonight and post them.
      Instgram: @Ebola.30
      • earthwormjim
        • Jul 2014
        • 434
        That would be helpful. Perhaps your car has been in an accident in the past?
        No modification of the lights should be needed. Can you read the part number on the lamps and plastic bracket?
        • MB07
          • Jan 2018
          • 62
          These 2 pics you can see where the holes are lining up but the top of the bracket is hitting the rad support
          This pic you can see where the lower part of the bracket is hitting the valence tab.
          Instgram: @Ebola.30
          • MB07
            • Jan 2018
            • 62
            Ive been under the car, everything looks straight. Whats weird is both headlights hit in the exact same place on both sides.
            Instgram: @Ebola.30
            • MB07
              • Jan 2018
              • 62
              134-365-00-LI
              134-366-00-RE
              Instgram: @Ebola.30
              • earthwormjim
                • Jul 2014
                • 434
                You have the driver's side head light on the passenger side in this picture.
                The projectors (low beams) are the outer most lamp. The reflectors (hi beams), are the inner most lamp.
                The part numbers tell you which side should be which too. LI means left side if sitting inside of the car. RE, means right side if sitting inside of the car.
                • MB07
                  • Jan 2018
                  • 62
                  Oh for Christ’s sake. That’s embarrassing. I’m going to go bury my head in a hole now. Thanks dude.
                  Instgram: @Ebola.30
                  • Blackout
                    • Apr 2011
                    • 4130
                    Aren't you glad we have R3v?
                    » PARTS FOR SALE
                    » TRANSACTION FEEDBACK
                    • earthwormjim
                      • Jul 2014
                      • 434
                      That's what I was trying to tell you earlier, I had thought you had swapped the right and left lights, and flipped them over to keep the projectors on the proper side.
                      I'm curious if you could have eventually made them fit though. Would be a rather unique mod!
                      • MB07
                        • Jan 2018
                        • 62
                        Life saver.
                        Instgram: @Ebola.30
                        • MB07
                          • Jan 2018
                          • 62
                          I actually had it all layed out in my head and everything on how to make them fit. Basically take the old steel brackets from the sealed beams, lay out your holes where the headlights are supposed to bolt up and fab out some adjusting rods to hold them in place. It actually would have been pretty simple. I might go back to the junk yard and find another get set of headlights off of a 5 series or a 7 series and see if I can make it work.
                          Thanks again for your help.
                          Instgram: @Ebola.30
