US ellipsoid wiring
  • Digitalwave
    is a poseur
    • 6292
    US ellipsoid wiring
    Alright, I searched for an hour and couldn't find it.
    Does anybody have a wiring diagram for the sealed beam to US ellipsoid conversion?
    RISING EDGE
  • DEV0 E30
    • Oct 2004
    • 8876
    Are the ellipsoid connectors included? If they are its easy.
    I didn't even need a diagram, I just matched the grounds, then the power wires. They may have even matched. Just be sure to leave enough wire that connected to the sealed beams before.
    Found this quickly searching:
    If they aren't I'd suggest getting some (ask Scott if he is still around?) otherwise I guess a wiring diagram would be the fastest way... but it won't be that clean without the connectors.
    • NC325iC
      • Mar 2004
      • 6565
      should be the exact same as wiring euros
      • Digitalwave
        is a poseur
        • 6292
        It would be very simple if it were 2 wires :) But mine have 3 wires. One brown (ground) and two blue/white I think. Do I just connect the browns and then connect the 2 into one for the other wire? Or do I leave the 3rd one off to the side?
        RISING EDGE
        • DEV0 E30
          • Oct 2004
          • 8876
          I'll check when I get home. I had 3 aswell.
          • erik325i
            • Jan 2005
            • 3567
            It should be exactly the same as swapping in Euro ellipsoids to your car. James C has a nice writeup about it.
            -Erik
            • Digitalwave
              is a poseur
              • 6292
              I don't have a test light or multimeter here at school, so I need to know the colors of the wires (James doesn't include them).
              RISING EDGE
              • erik325i
                • Jan 2005
                • 3567
                To make it really easy for you, I think the wire colors accually match up between your stock wiring and the wiring for the ellipsoids (at least they did every time I installed ellips).
                The wire that doesn't match up you won't use.
                -Erik
                • Digitalwave
                  is a poseur
                  • 6292
                  Awesome, that does make it easy.
                  RISING EDGE
                  • BDSax
                    Junkyard King
                    • Mar 2006
                    • 3594
                    sounds easy enough.... i can bring my DVM over
                    • MIKe30
                      • Sep 2006
                      • 2334
                      so what suggestion did you go with that made it work properly (lows stay on when highs are turned on)?
                      • Digitalwave
                        is a poseur
                        • 6292
                        You have to jumper two relays, I haven't done that yet. The highs are still great without the lows.
                        RISING EDGE
                        • MIKe30
                          • Sep 2006
                          • 2334
                          ic... i know it works fine like that (my angel eyes were like that) but it doesnt look as good imo... hope you do your own write up when you finish with all the wiring.
                          • WRX2M3
                            • Jan 2004
                            • 47
                            Can someone tell me what bulb's come in the U.S. ellipsoids? I picked up a pair and installed them but wanna go the H.I.D. route. Thanks in advance.
                            • asubimmer
                              • 6482
                              9006low 9005high
