I need some cheap, bright lights.
  • psloan
    • 9815
    Sealed beams arent cutting it for eith of my e30's - whats the cheapest way to get some brighter lights? All of the ebay stuff is tempting because its cheap - but i know its crap. What can i do with 200 per car?
  • NC325iC
    • Mar 2004
    • 6565
    you can probly get some used euro ellips for 200 bucks, actually i know you can
    if you dont want that you can get us ellips
    • E30 Reaktionär
      Site Manager
      • 14451
      I get a set of euro ellips off of ebay for $85 shipped. There was little pitting but they needed new adjusters.
      1992 BMW 325iC
      1978 Chevrolet Monte Carlo
      • Steve30
        • Sep 2005
        • 261
        There is a set of US ellips on San Diego craigslist for like $80.
        1988 M3
        2005 330ci
        • psloan
          • 9815
          What are the best lights i can get? What's the difference between eiro ellips, us, projectors, ect? I'm a headlight noob - 02's only get h4s and sealed beams.
          • Febi Guibo
            • Sep 2005
            • 407
            I have had almost every type of headlight...
            if you have sealed beams, one option is the cibie or hella e-code H4 style lamps; they drop in, and have a city light. For the price, people really like them.
            If you have US ellips, which are cheaper than euro ellips generally, you can:
            - run 9011/9012 HIR bulbs --brightest non HID lamps available
            - get D2S lamps rebased for 9006 sockets, and use OEM ballasts/ignitors from an E46 or many many other euro cars (eg, from a junkyard)
            - get an ebay HID kit --quality varies.
            Euro ellips: get high quality european osram silverstar H1s, or an fleabay HID kit... be advised, the fit for an HID bulb rebased for H1 holders is a tad tight, no biggie, but in my opinion, isn't as 'solid' or whatever as a 9006 or D2s style plug.
            • psloan
              • 9815
              What's a good source for h4s? They run like 60 per light, right?
              • AdironRider
                • Dec 2004
                • 3491
                200 should get you a very decent set of euro elips, but I cant even justify that much for lighting.
                Back to my roots
                • Rocla
                  • 922
                  I've searched ,but found e30 bolt on h4 lamps.
                  You could mix e21 and e30 allignmet part to use regular h4 lamps, abou 20e/each here.
                  Current:
                  BMW 320i 2d 2.0 m20 -88
                  BMW 325i Cabriolet 2.5 m50 -88
                  BMW 316i touring 1.6 m40 -90
                  BMW 320i 4d 2,2 m54 -01
                  • psloan
                    • 9815
                    Shouldn't h4s bolt on where sealed beams were?
                    • Rocla
                      • 922
                      About that i have no idea, I've never seen sealed beam e30 in my life. If that's true, should get sealed bema part for my 4*h4 conversion.
                      Current:
                        • 34847
                        H4s do bolt in where sealed beams were.
                        definitely a good upgrade for the money. the light output is just as good as ellipsoids - I just prefer the looks of smoked hellas.
                        • backtrail69
                          • Jul 2005
                          • 4471
                          I have H4s on my turbo car with dual filament bulbs, so with the single lights that I have highs and lows. I have H4s also in my 2002. They aren't Ellips with HIDs, but pretty damn good for the money.
                          :: PNW Crew ::
                          '87 325 4dr, '74 2002
                          • psloan
                            • 9815
                            I've got em in my 02 as well. Anyone running 2 hi/lows instead of running a hi low and a high?
                            • Rocla
                              • 922
                              I had it like that on my e21, liked it and planing to do this for my e30 also.
                              There is even h4 bi-xenon setup available with moving bulb, I bet 4 of those would rock.
                              Too bad sealed beam cars are nearly impossible to find around here and new sealed beam adjusting parts would most likely cost a fortune.
                              Current:
