Oh, also, do I need one of those relay harnesses? I see some kits come with them, with a fuse and relay in a wiring harness --- do I need that?
Help w/ HID's and Euro Smiley's
Is these going into a sealed beam car or a ellips light car? cause if it is a ellips car from the factory you don't have to do the relay mod. And you souldn't need that harness your talking about.
1992 BMW 325iC
1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hpComment
These are going into a sealed beam car - '88 M3.
I figured it was easier to ask all my questions in "phases", rather than bombard everyone in one post w/ all my questions, and get none answered.... :D
Do I need that harness for a sealed beam car?
This is what I was looking at:
Buy and sell electronics, cars, fashion apparel, collectibles, sporting goods, digital cameras, baby items, coupons, and everything else on eBay, the world's online marketplace
That the right one?Comment
Mines a sealed beam car and my HIDs did not come with any thing like that. I have had my HIDs in for about 6 or 7 months now with no problem. And you will have to do the relay mod for your lows to stay on with your highs.
1992 BMW 325iC
So I just run a wire from the #30 pin on the low beam relay to the #30 pin on the high beam relay?
Is that -safe- ? Don't want to burn up the fusebox...Comment
Ok, fair 'nuff.
Finally --- what about the city lights? How do I wire those up, on a sealed beam car?Comment
1992 BMW 325iC
Sorry if I was confusing all I was saying is that the factory 9006 plug for US ellip should plug into the ballast instead of cutting and splicing wires together, for some reason I thought you had US ellips.:: PNW Crew ::
'87 325 4dr, '74 2002Comment
And when you do the relay mod, you may want to drill the holes and run the wire through them and then solder them into place. Cause mine will come lose sometimes and then i will only have high beams on instead of both high and lows.
1992 BMW 325iC
Got it. So drill holes in the pins, and solder the wires into place on the pins.
Thanks for all the good info!Comment
precicely. I had HID's in my gti before I did the rallye lights and I didn't even cut any wires to hook mine up. I was just poking around to see what bulbs these use to see if I can use my HID's in them.Bryan - 1989 325i S50 swapped /1990 Audi Coupe QuattroComment
