smoked tails(yes another post)
  • nameisbradgreen
    • 270
    i know there are a lot of posts on smoked tails and yes i used the search...
    but this one DIY site http://e30.bmwdiy.info/red-tails/index.html only has red tails and i wanna smoke mine so what kind of paint did you guys use to do your smoked tails?
    thanks
    Brad
  • e30Matt
    • 5077
    The Tamiya Window Tint works fine as long as you go easy on it. My friend did it on his E36 tails and had quite a few problems with runs, but he applied it really heavily. Just go easy on it, and apply a few coats of clear over top of it when you're all done.
    • nameisbradgreen
      • 270
      this
      would this shit do the trick?
      This is a 3 oz. (85 g) can of Clear Transparent Black Window Tint Enamel Spray Paint.
      and do i have to put a clear coat on after?
      Brad
      • Skafrog
        • 1732
        sort of, but pactra makes a lexan tint spray that will work better, and it should also be at hobbytown.
        NASA MidSouth TT Director / GTS2 #018
        Mods: Coastal PS Fluid, 10w40 Oil
        Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
        • kencopperwheat
          King of Kegstands
          • 14396
          Yes, you'll need to put clear coat over it.
          Originally posted by Gruelius
          • AndrewBird
            The Mad Scientist
            • 11898
            This:
            Here:
            Here:
            Or here:
            http://www.carttonic.com/catalog/ind...36&pi_id=26443
            Hope that helps.
            Andrew
            • nameisbradgreen
              • 270
              clear coar
              what and where should i get the clear coat?
              • bmw4life
                • Apr 2004
                • 152
                i got a red e30 and was also thinking of doing smoked tail lights but was not sure how it would turn out so if you do it please show a picture so i can decide if i want to or not :)
