euro ellip install
  • jrobie79
    • Mar 2006
    • 2526
    euro ellip install
    based on this DIY article, which seems very thourough, where can i get the connectors to hook up the lights, i already have the stuff highlighted in red, so where can i find the other parts:
    http://bmw.e30tuner.com/articles_eurolight.php
    1 set of European Spec Ellipsoidal Headlights
    2 x High Beam Caps* [PN 63-12-1-381-190]
    2 x High Beam Connectors* [PN 61-13-0-007-445]
    4 x Circular Wiring Connectors [PN 61-13-0-007-445]
    About 8 feet of 16ga wire (18 is OK too, 16 is preferable)
    12 Crimp Splice Connectors for 14-16ga wire
    4 pairs of spade connectors (optional)
    An assortment of Heat Shrink Tubing (Alternatively you can use electrical tape, it is just messier if you ever change the wiring).
    1991 318i ---- 308K - retired
  • einstein57
    • Jun 2007
    • 10780
    junk yard for the caps and connectors. i ended p soldering the old ones to the caps and then useing a glue gun as a temporary substitute.
    www.gecoils.com
