Best bang for the buck?
  • z50_Jumper
    • Apr 2007
    • 1520
    Perfect, those H4's are just what I have been looking for, more light for less money! Thanks tjts1
    • z50_Jumper
      • Apr 2007
      • 1520
      Ok, so next question, what wattage bulb can I use on the stock lighting harness? I have been searching but don’t have much time due to work.
      • gearheadE30
        • Jun 2007
        • 3734
        H4 all the way up to 100 watts and same for the H1's. I think that is the highest power that is widely available, and I believe that is what is on my car along with independant fogs. All 6 lights on at the same time is absolutly stunning ;)
        Project M42 Turbo
        • tjts1
          • May 2007
          • 1851
          Same here. 90/100 H4 and 100w H1 on stock wiring harness with those autopal lights. I think I had to up the high beam fuse by 5a.
          I'm actually thinking about upgrading to the multi surface reflector version of these lights.
          http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
          • SchnellerVert
            • Sep 2005
            • 3948
            130/110W H4 are out there but would suggest relaying at that wattage.
            • DaveSmed
              • Apr 2007
              • 1407
              Blue bulbs = ricer crap.
              -Dave
              2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
              Need some help figuring out the ETM?
              • StereoInstaller1
                GAS
                • 22679
                BMW uses headlight relays. Unless you are planning on running 300 watt low beams, you are OK with whatever bulbs you wanna run.
                Closing SOON!
                Thanks for 10 years of fun!
                • tjts1
                  • May 2007
                  • 1851
                  I think bulb life goes down a lot once you get past 100w.
                  I know. Thats why you scroll down and and get the 90/100w white bulbs for $6.
                  • DaveSmed
                    • Apr 2007
                    • 1407
                    Ah. I see.
                    BMW does use relays, but the weak point is the harness. If your sticking bigger fuses in, or getting excessive voltage drop, an additional relay with a dedicated power feed might not be a bad idea. Check control will throw a shit fit though.
                    -Dave
                    • StereoInstaller1
                      GAS
                      • 22679
                      Ah. I see.
                      yeah...weaksauce on the 200 ga wire.
                      Closing SOON!
