Sealed Beam->US Ellipsoid->Prolumen HID
  • 808AWD325xi
    • Sep 2007
    • 359
    Has anyone converted from sealed beam headlights directly to US Ellipsoids with a Prolumen HID kit?
    I am looking for guidance on how to make this work without modification to the factory wiring harness.
    The headlights I intend to purchase from BMW are:
    63-12-1-385-797 (left)
    63-12-1-385-798 (right)
    and a Prolumen HID kit from the bfc group buy:
    Which bulb type should I specify for this setup?
    Do I need anything else to complete the install? Part numbers required, if any, would be greatly appreciated.
    If this has been answered before, my apologies. I did a search and everything I found was related to euro ellipsoids.
    Thanks in advance.
    Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
  • nosignal
    • Oct 2007
    • 274
    Converting sealed beams to US Ellipsoids is identical to the Euro process, minus the wiring for the city lights as they aren't present on US lights.
    US Ellipsoid low beams use a 9006 bulb stock, high beams use a 9005.
    Are you buying the lights new, or are you going the JY route? If buying new, you'll want to make sure you get all the related hardware (mounting brackets, bulb wire harnesses x4, etc). The harnesses for the 9005/9006 bulbs are very easily adapted to the factory wiring for sealed beams, so there's no permanent modification to the factory stuff needed.
    I'd recommend getting the SB -> Ellip conversion done first, verifying that it works with regular halogen bulbs, and then throwing the HID kit in. It won't be any more difficult and will save you a lot of troubleshooting later on if you end up with a defective bulb/ballast/etc.
    ::: Present -- '87 325e, '95 525i
    ::: Past -- '91 318i, '95 540i/6, '85 323i Euro, '86 325es, '86 325e, '84 318i
    • Van Westervelt
      • 9365
      Paul, you piss me off. How long did I go over all this with you? You will to modify the plugs to make it work, and you will have to buy the plugs.
      I showed you how I could do the whole thing with only one splice, and with HID's and Euro ellips.
      Its your money man.
      • Van Westervelt
        • 9365
        • Gooch
          • Dec 2006
          • 1674
          I went through the same thing, Febi explains it pretty well in my post.
          '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
          '87 535i - Vacuum brake conversion [SOLD]
          '93 525iT - 5-speed swap - 320k and counting
          '09 328xi - 6-speed
          • Van Westervelt
            • 9365
            http://www.r3vlimited.com/board/showthread.php?t=101322
            Thats actually more complicated than it really is.
