fitting HIDs into fogs question
  • ///M42 sport
    • 3952
    I was wondering if its possible to fit the apexcone kit into the fogs w/o any modification of the fog housing. I would rather cut up/splice the wires on the HID kit than poke holes in the stock assembly. Thanks.
  • atomic
    • Jun 2007
    • 5691
    I have yet to install mine in the fogs but it appears that the bottom of the HID bulb housing will come very close if not going through the bulb replace door. Looks like there is no way around drilling a 1/2" hole to accept the bulb and wiring. Just RTV it after your done to keep the water out.
    All you will alter is the door itself and not the housing at all...
    • ///M42 sport
      • 3952
      Cool. A second question...does the HID fog improve functionality?
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        It will sure make them brighter. If you have yellow-ish bulbs (like 3K or so) then they can help cut through fog.
        • Fidhle007
          I can fly, motherfucker
          • Oct 2005
          • 7209
          HID fogs were the best thing I ever did. Drill a hole and RTV the shit out of them and you'll be good.
          '89 325is S50 Track Montser
          '04 X5 Daily/Tow Vehicle
          http://www.avarestoration.com
          http://www.myspace.com/brendanfiddle
          Click here if you want to be my zombie slave...
          http://www.youtube.com/user/Fidhle007
            • 34835
            you are going to have to drill something, it's simplly not going to fit without some modification.
