Brake Lights on...
  • Uber E30
    • 1409
    Brake Lights on...
    So i just installed euro trim and now my brake lights are staying on. I cut the existing side markers and used heat shrink tubing on the ends. Do i just need to complete the circuit or is this just totally unrelated?
    Any suggestions would be helpful because CHP pulled me over but the dood was nice and didnt give me a ticket. Next time im guessing i wont be lucky, plus getting read ended doesnt sound fun either.
    -Alex
  • Uber E30
    • 1409
    bump... cant drive the e30 till this gets fixed please help!
    -Alex
    • e30this
      • 3580
      well if cutting the wires caused your problem then I would connect the plugs back up.
      I installed euro trim on my e30 and just pulled the bulbs and packed the ends with vasaline.
      • Uber E30
        • 1409
        See im not totally sure it happened when i cut the wires. Thats just the only thing i did recently. Guess i need to pull the bumpers this weekend.
        -Alex
        • e30this
          • 3580
          you dont have to pull the bumpers.
          since you already cut the ends off pull the rear ones in through the trunk. The front you should be able to reach from under the hood.
          another thing if you dont think its that then look under your dash and on the brake pedal there is a button that touches it. Maybe the bracket bent for some reason.
          that switch could have went bad too.
          • ADEN
            • 620
            brake switch brake switch.i had this problem check it test it and position it very well.
            • Fidhle007
              I can fly, motherfucker
              • Oct 2005
              • 7209
              Pull out the knee bolster and check the brake switch first, it's the simplest and most likely source of your issue.
              '89 325is S50 Track Montser
              '04 X5 Daily/Tow Vehicle
              http://www.avarestoration.com
              http://www.myspace.com/brendanfiddle
              Click here if you want to be my zombie slave...
              http://www.youtube.com/user/Fidhle007
              • Uber E30
                • 1409
                Oh awesome thanks guys... gonna go try that later today.
                -Alex
                • kenika65
                  • Aug 2007
                  • 1336
                  you may need to buy a new break switch or adjust your break pedal
                  1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
                  1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
                  • Fidhle007
                    • Oct 2005
                    • 7209
                    "Break?"
                    Maybe he needs a new pedal stop to reduce the brake pedal travel?
                    Of course some silver Krylon might get that switch working like new...
                    • kenika65
                      • Aug 2007
                      • 1336
                      lol brake ya ya I had my brake light staying on and to fix it I had to adjust the break pedal so that it would contact the brake switch which then turned the lights off!
                      • Uber E30
                        • 1409
                        Awesome it was the brake switch... thanks alot guys!
                        -Alex
                        • Fidhle007
                          • Oct 2005
                          • 7209
                          So you adjusted the pedal rather than the flimsy, easily adjustable piece of sheet metal that holds the switch? Did you paint everything while you were in there?
