Help identifying plugs
  • Paul-Z
    • Jan 2018
    • 159
    All of these are located up front near the headlights...thanks in advance!
  • Paul-Z
    • Jan 2018
    • 159
    Anyone?
    • twright
      • 707
      It looks like you're going to have to get out a wiring diagram and start looking at wire colors.
      • Paul-Z
        • Jan 2018
        • 159
        Yeah I was being lazy assuming there’s a wealth of knowledge on this board and that someone has surely come across these at some point ‍♂️
        • roguetoaster
          Biggus Tippus
          • 7818
          Are they tied in properly to the main looms or are they on top or add ons?
          Frabkly, they don't really look like stock BMW plugs.
          • Paul-Z
            • Jan 2018
            • 159
            They are indeed tied into the stock loom
            • Paul-Z
              • Jan 2018
              • 159
              Bump
              • surebimmer
                • Jan 2004
                • 978
                Driver or pass side headlight? What year is your car? One looks like the fan temp sensor wiring 3 wire. One looks like side marker plug 2 wire rectangle rubber boot. Coil plug main wire single?
                • bradmer
                  • May 2016
                  • 362
                  Requires year, make and model information to assist. Can also Google r3v / e30 wire plugs front (with your rear, make and model for 24/7 assistance). Good luck!
                  • lukeADE335i
                    • Apr 2013
                    • 1384
                    Also Google: e30 Electrical Troubleshooting Manual + your year and model - eg. 1986 325e etc. You will find a pdf manual for your specific car. These are factory manuals that have comprehensive wiring diagrams, troubleshooting info and a photographic plug / part identification section.
                    Very helpful (sometimes you need to go a year or two either side if your specific manual isn't in the list). The factory troubleshooting manual for my car was extremely helpful when I did my swap. Good luck.
                    My e30: OEM+ with M30B35
