Another HID Question
  • Beastolizer
    • Nov 2008
    • 1517
    Ok, so now what I wan't to know is, can I achieve the same light effect of an H1 6000k bulb with a 9006 bulb. And is it possible to get an HID 9006 bulb that will fit in US ellipsoids?
    '91 Brilliantrot 318iS - Sold
    '95 e34 s50 Touring - P/O
    '87 Alpine White 325iS - Current
  • reelizmpro
    • 9556
    Yeah but you don't really need HID's in the high beams, given that they aren't really used that much. That's sort of a waste don't you think? Besides, HID's need a few seconds to 'warm up' and the ballasts probably won't like short On/Off bursts if you decide to flash your high beams.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Beastolizer
      • Nov 2008
      • 1517
      True. So what should I run in my highs?
      • EA8
        • 328
        regular halogens should do the job ... many brands out there, just depends on how much you're willing to pay for a set of bulbs (sylvania makes some decent ones).
        cheers ...
        • Liam
          • 753
          H 9005 halogens, you have some wiring work ahead of you as well if you are switching from sealed beams to ellipsoids.
          I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
          • Beastolizer
            • Nov 2008
            • 1517
            I have plug and play connectors as well as an older brother very well trained in the art of working on BMW's. :D
            Would these do the job just fine?
            Brandsport offers a premier selection of molding and trim for domestic and imported cars plus many other applications all backed by our best-in-class customer service and satisfaction.
            • EA8
              • 328
              should do the job ... cheers
              • ZJP
                • Dec 2008
                • 52
                Real quick, what bulb type do the US Ellipsoids use? Thanks.
                WTB: '89-'91 5spd 318is/325is in Tri State area.
                • reelizmpro
                  • 9556
                  9006 lows and 9005 highs
                  88 M3 - LACHSSILBER
                  • Beastolizer
                    • Nov 2008
                    • 1517
                    But a lot of people run HID's in the lows and the 9005's in highs.
                    • joonsup
                      • 776
                      i wouldnt use HIDs in the high beams. You may burn them out quicker since you don't give them enough time to warm up unless you plan on having the high beams off for a while each time you use em
                      • Beastolizer
                        • Nov 2008
                        • 1517
                        I didnt say HID's in the highs...
                        • Beastolizer
                          • Nov 2008
                          • 1517
                          Read my new question above!
                          • Van Westervelt
                            • 9365
                            Euro and US Ellips use 2 different bulb types. As stated a few times in this thread, US Ellips use a 9006 low & 9005 high, and a Euro Ellips uses H1 for low and high.
                            So if you bought bulbs for Euro Ellips, they will not work in US Ellipsoids.
                            • Beastolizer
                              • Nov 2008
                              • 1517
