what supposed to be holding my battery?
  • guibo09
    • Dec 2008
    • 834
    i have a late model (90). whats supposed to be holding my battery down? i still gots the plastic tray for it, and thats good. then there is a long thin bolt on the back that just kind of wedges the battery. i know this isnt how it supposed to be.
    anyone offer any insight on proper battery mounting?
    90 E30 325i
  • asubimmer
    • 6482
    the cables hold it down good enough ;)
    • Ray Smoodiver
      • Jun 2004
      • 8809
      There should be a bracket that the long bolt screws through to clamp one end of the battery down.
      • guibo09
        • Dec 2008
        • 834
        okay, thats what im missing. anyone have the part number, realoem isnt helping
        90 E30 325i
        • Liam
          • 753
          If you have the correct battery it will hold it down by the "lip" on the bottom edge (also locks it into a channel in the front).
          I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
          • guibo09
            • Dec 2008
            • 834
            i imagine thats a bmw only battery?
            i imagine no one uses these anymore... if im replacing it with a standard sealed battery, what are my options?
            90 E30 325i
            • Liam
              • 753
              No it's an MT91 or MTP91 from Interstate Battery (used to be called an MB66) I'm sure a lot of manufactures and suppliers still have direct replacements for them.
              Very common European battery.
              • guibo09
                • Dec 2008
                • 834
                ok thats good news. so since my battery needs to be replaced i will get a mt91 style.
                to clarify, to hold it down like stock, i need the long bolt plus a clamp (which im missing)?
                90 E30 325i
                • Liam
                  • 753
                  The long bolt should have a little metal angle bracket foot thing on it take a look at one of the parts pimps sites (real OEM or whatever)
                  • guibo09
                    • Dec 2008
                    • 834
                    im gonna buy part #10. hopefully it's everything i need
                    90 E30 325i
                    • mooseheadm5
                      • Apr 2009
                      • 375
                      This is listed as a group 47 battery some places. You can also use a group 49 (aka MTP-93) if you have a lot of stereo equipment.
                      -P
                      Moosehead Engineering
                      • Liam
                        • 753
                        Yep, that's the one.
                        • Liam
                          • 753
                          EDITED
                          I read it again and my reply was silly.
                          Yes Group 47 and the 49 will fit as well (kind of big though).
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            What the hell is number 13 in that picture?
                            • Liam
                              • 753
                              Acid, BMW batteries come dry and are filled at the dealer (at least the did when I was there)
