what supposed to be holding my battery?
  • guibo09
    • Dec 2008
    • 834
    does the battery need to be vented to the outside? there is the large flappy vent right near by the battery, is this enough? or should i pipe a tube from the battery vent hole to the rubber grummet at the base of the battery tray?
    does the tube exit have to be higher than the battery?
    90 E30 325i
    • Liam
      • 753
      You should have a tube that drops out the bottom of the car that goes to the vent (it's there in case the battery pukes).
      I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
      • guibo09
        • Dec 2008
        • 834
        the PO didnt vent his battery... so no signs of a vent tube.
        where exactly does the tube exit? does it exit right under the battery plastic tray? there is a hole with a rubber grommet i can easily pass a tube through. or does it go somewhere else?
        90 E30 325i
        • Liam
          • 753
          Yes it exits at the bottom of the car. Small plastic tube through a grommet in front of the right rear wheel)
          • guibo09
            • Dec 2008
            • 834
            thanks! i found the tube, and the little expansion container for the vent that goes to the bottom of the tray on realoem. cheap parts too.
            90 E30 325i
            • Liam
              • 753
              You're welcome, glad I could help.
              • M3Driver
                • 32
                I have the factory plastic tray and use a small ratchet strap to cinch it down.
                To keep the strap in place, I slotted the battery tray on each side of the battery with my cutting wheel, and then passed the strap through under the tray and back up again on the other side. The ratchet itself sits between the battery posts and is easy to access.
                It works really well: very snug, cheap, easy to remove/install, passes tech, and you probably have one in your garage waiting for a decent use :)
                Brian
                Used BMW Parts!!
                • Merlin8
                  • Apr 2013
                  • 160
                  Originally posted by asubimmer
                  the cables hold it down good enough ;)
                  the weight of the battery will weaken the cables during breaking and acceleration and eventually they will break. ive had mine strapped down with a truck bed strap since the stock pin rusted out for 6 months but still the cables bent and began to break. scary electrical issues on the freeway today. not good.
                  • Mr. Tasty
                    • Jul 2011
                    • 3421
                    awesome. You just bumped a 4 year old thread.
                    Kudos
                    2014 Alpine White 335i MSport
                    (Daily Driver)
                    Full Mperformance Aero
                    KW V2 Coilovers
                    VRSF Catless Downpipes
                    • diamonddonbmw
                      • Sep 2012
                      • 124
                      Thank you also!! I've been looking for this info too��
                      1991 318is, AWII, Eibach/GC, Koni
                      Riverside CA
