Brake Light connection and brake light not working
  • Synr
    • Sep 2021
    • 31
    Was wondering if someone could help me understand how to test my wiring harness for my brake lights. the fuses/relays are fine, and the connection is clean. my right brake light does not come on. i am having trouble testing the connector and i am not sure how to figure this out
  • It's Soda Not Pop
    • Jan 2022
    • 871
    I had this issue on the RS of my car years ago. The harness that's on the tail light housing probably has a short.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • Synr
      • Sep 2021
      • 31
      you are correct. kind of, the tail light itself has a short somewhere in the custom wiring. the actual harness on the car works just fine. need to find someone who can fix my tail lights now
      • It's Soda Not Pop
        • Jan 2022
        • 871
        My old set I wiggled the wires around until the lights would come on. I then taped up the wiring to pinch it so that it would work. That worked for 2 years and then I replaced them with new ones.
        88' Seta 2.7i Zinno
        • Synr
          • Sep 2021
          • 31
          I figured it out. something on the wiring harness for these LED custom set was not done right and one of the wires shorted. out the stock set in for now and will have to get them all checked
