Anyone know what this is?
  • Jcrunk
    • Mar 2023
    • 6
    Hi there,
    upon further searching around under my dash I found this black box thing packed around foam up above a type of bracket space above where my ECU goes...
  • reelizmpro
    • 9558
    Looks like an alarm to me.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Jcrunk
      • Mar 2023
      • 6
      I did some further digging and got this
      • Jcrunk
        • Mar 2023
        • 6
        should I cut it out man? I have a no start issue... that thing is dated 1988 lol
        • reelizmpro
          • 9558
          If it no longer works, go ahead. If you're starter cranks but engine doesn't start then it's not the alarm. All alarms to my knowledge only disable the ignition switch so if you turn the key and nothing happens then look for a starter kill relay under the column and bypass it. If the engine is cranking and just not starting then you have another issue, like faulty OBC (if you have one) relay box.
          88 M3 - LACHSSILBER
          • alpinaseeone
            • Jan 2023
            • 85
            Not necessarily true - I have an 80's alarm installed and if unplugged / armed, the car will crank but no start. OP's start problem could be alarm
