Canbus Heads Up Display for Megasquirt
  • ovo_e30
    • Aug 2020
    • 36
    Hi guys,
    I got tired of having a bunch of bulky standalone gauges in the car (AFR, boost, oil pressure), so I ended up designing and building a small HUD that pulls data straight from the Megasquirt CAN bus. It started as a personal project and turned into about a six month effort between hardware, firmware, and the housing, but I’m really happy with how it fits into the E30 interior and keeps things looking clean and OEM-ish.
    The HUD currently displays:
    AFR
    Vacuum / Boost
    Coolant temp
    Intake air temp
    Oil pressure
    Battery voltage
    It can be powered either by 12V from the car or by 5V over USB (one at a time).
    This does not work with stock ECUs. It’s intended for Megasquirt setups only.
    I wasn’t planning on selling these and originally built it just for my own car, but I figured I’d share it here and see if there’s any interest in something like this within the community.
  • Panici
    • Dec 2009
    • 2469
    Looks awesome!
    Can you share some more about the setup? What kind of microcontroller & screen?
    Is this something you would be looking to sell? Seems like it would work well in my MS3X powered E30.
    '87 BMW E30 325is Turbo
    '98 BMW E36 328i
    • ovo_e30
      • Aug 2020
      • 36
      Originally posted by Panici
      Looks awesome!
      Sure!
      The setup is quite simple in terms of architecture, which includes the ESP32-S3 brain, a generic 2.8" IPS LCD display, Canbus transceiver, MCP ADC for the oil pressure transducer, and various buck converters for power conditioning.
      I was interested in selling a few and seeing if there were any interests otherwise I was going to keep them as spares.
      • Panici
        • Dec 2009
        • 2469
        I'm definitely interested (as long as I can customize what is displayed, even if that means writing code)
        '98 BMW E36 328i
        • ovo_e30
          • Aug 2020
          • 36
          The display is fully customizable so you can send whatever code you want to it so you can get it to do what you want. I can definitely provide the pinouts for the SPI for each module if necessary. Lemme know!
          • e30m3s54turbo
            • Jun 2010
            • 3268
            I a have couple e30 on MSII. I might be interested also.
            • ovo_e30
              • Aug 2020
              • 36
              Sure! If there's any more info I can provide lemme know.
