2) cdt ef-80 for ib setup in rear side panels
  • brn2ply7
    • 301
    specs:
    have a set of cdt hd-62 components in door pods i am building right now so i am looking to add as little weight as possible and get some more nice tight low end.
    89 325i parts car
    90 325i in progress
    ground control 400f 700r-koni adjustables-koni adjustable sways-reinforced control arms-ground control camber plates-e36 cabrio shock mounts-4.10 lsd-5 speed swap in the works
    --tryng to join the schwarz army one day at a time--sigpic
  • Jean
    • 18228
    I had the 10" versions of those, and IIRC they work well in Sealed Boxes, not IB. When a sub/woofer doesn't have huge XMAX they will be easy to bottom out in IB configuration... plus these specific CDT subs are more of SQ subs, not meant for SPL.
    Good luck.
    • StereoInstaller1
      GAS
      • 22679
      IMO, nothing with a Qts under .6 sounds for shit in IB
      Closing SOON!
      Thanks for 10 years of fun!
      • brn2ply7
        • 301
        anY IDEAS THEN FOR A FREE AIR 8'S MAYBE A FREE AIR 12 I COULD MOUNT IN THE SKI PASS?
        MAYBE:
        DIAMOND AUDIO D312D4.2?
        89 325i parts car
        90 325i in progress
        • brn2ply7
          • 301
          Would those two 8" cdts sound good in a small sealed enclosures inside the car as opposed to the trunk. The are supposed to play well with small air space... I am not looking for real slamming bass as i rarely listen to rap and hip hop i mostly listen to rock/blues and am looking for low end sq to keep up with my components without adding a ton of weight. If i made an enclosure to go in the back seat maybe i could fiberglass it to fit in the rear seat corner with a nice sealed 10 and have it be removable for scca events and extra passengers.
          89 325i parts car
          90 325i in progress
          • StereoInstaller1
            GAS
            • 22679
            If you have fiberglass skills, make new rear side panels with boxes behind them...
            Closing SOON!
            • brn2ply7
              • 301
              ha i wouldnt necessarily call them skills...but i can try haha...i just bought another e30 today that i am gonna swap my 5-speed and suspension and exhaust into so i might just look into one of your boxes since this car is soooo much cleaner than my current e30. I figure that if i take out the trunk tar it would about equal the box weight. My current e30 was pretty light 2650lbs and i wanted it to stay light but this one id rather keep clean with the stereo install.
              89 325i parts car
              90 325i in progress
