I bought an aftermarket alarm. Where would the best place to mount the control box be? I was going to stick it in the trunk but I read that the OEM one is behind the glove box. The kit comes with remote entry and remote ignition. Also, is there a "best" spot for the siren? Kruzen was telling me that his was mounted where the battery would go under the hood. My battery, however is under the hood. Thanks.
Alarm - where to mount?
Tags: None
Maybe on the passenger side firewall? Or behind passenger headlights?
What alarm did you get? I'm looking around for something now, there have been a series of breakins in the neighbourhood. Neighbours brand new JL Amp, sub, and alpine HU were stolen!! -
cant u just leave it inside the knee bolster cover? That's where mine is, and I would imagine that that's the most convenient spot. If you ever need to adjust the sensitivity, all you need to do it take off those 3 lil clips.~ Go Canucks Go! ~
Re: Alarm - where to mount?
put the alarm under the knee bolster, get some zip ties and toss the siren under the hood :)Originally posted by btm4kI bought an aftermarket alarm. Where would the best place to mount the control box be? I was going to stick it in the trunk but I read that the OEM one is behind the glove box. The kit comes with remote entry and remote ignition. Also, is there a "best" spot for the siren? Kruzen was telling me that his was mounted where the battery would go under the hood. My battery, however is under the hood. Thanks.Comment
I have a small battery so I was able to bolt the siren right next to it. I ended up sticking the box above the knee bolster. So far I've just wired the main power and siren. Everytime I connect the wires to the box the siren goes off though :?
Axxe - I have a Prestige APS-996A. I saw it at my local Car Toys for $399. Ebay has it for ~$140. I would, however, not reccomend it. One wiring harness has 24 wires. The other has six. Its a PAIN to figure out.
just like everyone said already: put it under the knee bolster, if your alarm has an antenna (the one on my '85 does) then run it up inside your driver side a-pillar. my siren is next to my air filter (on both of my 318). i dont know what you drive but if its a 318 (any year e30) then there is a perfect spot right next to the air filter.'91 318isComment
a good spot for the siren is behind the headlights, there's plenty of room there. (at least with the m42s).~ Go Canucks Go! ~
Well, I am leaning towards this system DELTA DA-1005 Remote Start Car Security System. Anyone have experience with it?Comment
It looks fine. However, if you're going to install it yourself.. good luck with the remote start. If I were to do this over again I would have got a simpler system. Its not fun figuring where each of the 50 wires go.Originally posted by AxxeWell, I am leaning towards this system DELTA DA-1005 Remote Start Car Security System. Anyone have experience with it?
BTW, I installed the siren next to my battery.
Well, it's going to be fun finding all the wires. I have all the wiring diagrams that I need for the car, and I have "hot wired" the car before. That was when I was having trouble with the neutral safety switch. Nothing like stealing your own car!!Comment
