so i put a head unit in. i wired it all up according to some instructions found online as to what the colors were.. i used 4 prong plugs so it plugs in and out...let me get to the problem.. it has a sort of wine. idk what this could mean.. i then replaced all the speakers thinking this could fix it but it still hasnt.. anyone have an answer to this.. its currently not grounded but having it grounded didnt change anything so i didnt bother..
question...need help pleeeeease
Tags: None
Does the sound change when you turn the lights on? You may have tapped into the dimmer wire for the display. -
nope thats not it.. its wierd.. it sounds good with the car off. but it still doesnt go loud. when i first let it run it doesnt sound bad but once i move it sounds retarded... im soo lostComment
did you remove the stock amp? did you bypass the stock speaker wires? you must ground things for them to work right.Comment
Does the whine change when the RPMS of the engine change? If so then some sort of signal isolator or change of routing of wires would be needed, this was always prevalent with the GM's that had the ignition on the firewall (right behind the stereo. Oh and ground it you don't want to be replacing it every month or so.85 Toyota pickup.
85 325e sedan daily driver.
Various s13 bits for sale. Also a complete stroker kit to be listed soon.
DriftSTL.com driftpirates.comComment
