Premium Speaker Question
  • aworthybrother
    • May 2007
    • 899
    Just curious if its a good idea to just replace only the factory amplifier and keep the stock premium speakers? If so, what should be the correct watts for the replacement amp?
    Thanks.
  • aworthybrother
    • May 2007
    • 899
    anybody can suggests what good aftermarket amp for the stock premium speaker
    • cmflossin
      • Jun 2008
      • 138
      definitely just get rid of the factory amp and re-run your wires. i'm running 65x4 with high pass crossovers. 35x4 to 65x4 would probably do just fine. above that, who knows? i have no experience with more power than that.
      • aworthybrother
        • May 2007
        • 899
        Thanks.
        I found a 4-channel car amplifier - 70 watts RMS x 4 at 4 ohms at a good price. Can I use this to power my stock premium speakers?
        • aworthybrother
          • May 2007
          • 899
          to audio gurus....
          if i use a 70watts x 4 to run the front and rear and an infinity basslink, am I required to install a capacitor?
          • Mless5
            • Jul 2006
            • 817
            No.
            '96 328is
            '97 m3
            '04 zhp
            • aworthybrother
              • May 2007
              • 899
              Thank you. More noobie questions....
              1. Can I use the stock radio to connect this 2 amps?
              2. Also, what does the pre-out means? Can I use the pre-out to connect the basslink? (Front & Rear RCA to 4-channel amp then use the pre-out to connect the basslink)
              3. Wiring question, let me know if this looks correct or retarded...
              LF
              RADIO ---> Grey/red (soldered to RCA) ---> AMP ---> yellow/red ---> speaker
              RADIO ---> Grey/Purple (soldered to RCA) ---> AMP ---> Yellow/Brown ---> speaker
              RF
              Grey/White --> AMP -- > Blue/red
              Grey/Brown --> AMP -- > Blue/Brown
              LR
              Black/Red --> AMP -- > Yellow/Black
              Black/Purple --> AMP -- > Yellow/Brown
              FR
              Black/White --> AMP -- > Blue/Black
              Black/Brown --> AMP -- > Blue Brown
              • aworthybrother
                • May 2007
                • 899
                any response from the audio gurus?
                • StereoInstaller1
                  GAS
                  • 22679
                  LF
                  RF
                  LR
                  FR
                  Good god, man, what the hell is that chart?
                  First, what deck, please?
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • aworthybrother
                    • May 2007
                    • 899
                    Lol! its a combination of the wiring diagrams from different posts...
                    I guess, to make my question simple - how do I connect 2 amplifiers (4 channel and basslink) using the stock radio from my 1992 318ic if possible? I want to keep my stock radio since I am still undecided what to replace it that would look oem aside from the expensive CD43.
                    Thanks Luke for responding.
                    • AndrewBird
                      The Mad Scientist
                      • 11897
                      Take the speaker wires off the stock deck and hook them to the "speaker level input" on the amp. Then run RCA's from the Pre-Out on the amp to the Basslink. Simple as that. Here is the factory wiring diagram for your car:
                      Take a look at page 83 for the speaker wires coming off the deck.
                      • aworthybrother
                        • May 2007
                        • 899
                        Thanks, since I do not have the wires from "speaker level input", can I solder the RCA from the wires from the radio (center pin - positive, outershiled - chassis ground)?
