Headunit cuts out with I turn the headlights on?
  • Digitalwave
    is a poseur
    • 6299
    Ever since I installed my Eclipse headunit with no built in power, the deck turns off when I turn on my headlights for a second, but turns right back on. It happens whenever I flick my high beams as well. And SOMETIMES, but rarely, it goes of when I hit the brakes and the brake lights turn on. This never happened with my old Pioneer headunit, and they are wired up to the same power lines, the only difference I can think of is that my Eclipse dims at night, so I wired this deck to the dimmer wire whereas the Pioneer wasn't hooked to it.
    Any ideas what the problem might be? I was thinking about finding another 12v source for it and seeing if its that, but it seems like it might be more of an issue with the dimmer?
    RISING EDGE
  • 87 325iS
    • Jun 2004
    • 277
    Mine kinda has the same problem, sometimes it cuts out when I hit the brake to put it in gear (yes its auto), but then comes right back on. :?
    Amber Fire Pearlcoat 2000 Dodge Dakota R/T
    Schwarz 1991 BMW 535i [Daily Driver]
    Dark Currant Pearl 1996 Acura Integra GS-R [For Sale]
    Orientblau Metallic 1994 BMW 740i [Sold]
    Alpinweiss 1987 BMW 325iS [Junked]
    • kencopperwheat
      King of Kegstands
      • 14396
      Does the whole deck turn off, or just the display? I'd find a larger 12V power lead.
      Originally posted by Gruelius
      • Digitalwave
        is a poseur
        • 6299
        It all cuts off, the music turns off for a second...
        RISING EDGE
        • Digitalwave
          is a poseur
          • 6299
          bump
          RISING EDGE
          • bimmerphile
            • 3495
            well man, you're losing power to the deck (duh). I'd run wire directly to the deck as to be higher up on the power distribution chain.
            • Digitalwave
              is a poseur
              • 6299
              Alright, I am getting sick of this so I tried to fix it today. I changed the ground, the constant power, and there was no change in the problem. I then wired the switched power to a constant line, and it still happened! I figured the problem was in the power coming in, but I changed both of them and no dice? Any ideas?
              RISING EDGE
              • Jordan
                • 12916
                disconnect the dimmer lead.
                https://mtechniqueabs.com/
                • Digitalwave
                  is a poseur
                  • 6299
                  Did that, I figured that would fix it... no go. Same effect with the dimmer off.
                  RISING EDGE
                  • Mike 91 318ic
                    • Jun 2004
                    • 429
                    Use a test light on the constant 12v power wire and see if the light goes out when you turn on the headlights. If it does your problem is with that wire somewhere. You'll have to find a new power source. If it doesn't try doing the same with the acc. power wire. If the test light goes out on the acc. power then you have to acc. wires.
                    • NickP
                      • 257
                      I would find a new ground and run the constant power off of the power distribution block off of the passenger side firewall.
                      • Digitalwave
                        is a poseur
                        • 6299
                        Like I said, I changed the ground and the constants with other ones and the problem remained. I know its not the ground because I ran it to the ground in the trunk, which is good. Its one of the power leads.
                        RISING EDGE
                        • e30Matt
                          • 5077
                          Try pulling from the cig lighter 12V and see if that does it.
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            I would just run a new fatty wire from under the hood and hook that up to the deck. I would also run a ground stright into the transmission tunnel behind the headunit with a self tapping screw. I hate splicing into existing wires when it comes to things like this.
                            • Pieter E30
                              • Jan 2005
                              • 48
                              Sounds to me like its the deck!!!!!!
