Help please! Cd deck wiring and fuse box
  • 04F2504X4
    • Nov 2008
    • 121
    I am trying to wire my cd deck up. I cant figure out for some reason which wire is power and which one should go to my illumination wire ( yellow). Please help me out on which stock wires should be going to those.
    Also my Haynes manual does not show which fuses are which. Shows a picture of my engine bay with a diagram that should be in my engine bay but no longer is not.
    The car is a 1986 bmw 325.
    Thanks for any replies!
    Ben
  • E30 Cabrio
    • Oct 2006
    • 1954
    A search should bring up a wiring diagram as this is a commonly asked question.
    1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
    Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
    Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
    • Disaster Inc
      • Oct 2007
      • 429
      Second time I posted this link tonight http://wedophones.com/BMWManualsLead.htm
      • 04F2504X4
        • Nov 2008
        • 121
        Thanks disaster. Sadly im horrible at the wiring diagrams and they dont make much sense to me. Looked through that a couple times.
        Could someone provide the color of the power and illumination wire??? Thats what i need.
        And the fuse box diagram.
        • StereoInstaller1
          GAS
          • 22679
          If you download that wiring diagram book, look under "power distribution box" and scroll down a page or three, there is a fuse list.
          Closing SOON!
          Thanks for 10 years of fun!
          • 04F2504X4
            • Nov 2008
            • 121
            Oh!. Sorry for my laziness thanks stereoinstaller.
            And if it helps anyone i found out that the power wire is green/red. I ended up wiring power and illumination(yellow/battery) to that same wire cause i never figured out which one the (yellow/battery) should be to.
            • StereoInstaller1
              GAS
              • 22679
              Yellow on your deck is NOT illumination.
              Yellow is constant power, to retain memory.
              Closing SOON!
              • 04F2504X4
                • Nov 2008
                • 121
                Oh..... well i never found a constant power!
                • StereoInstaller1
                  GAS
                  • 22679
                  Red/Green turns yellow at the deck: goes to yellow on your aftermarket deck.
                  If you are retaining memory, you must have found it.
                  Luke
                  Closing SOON!
                  • 04F2504X4
                    • Nov 2008
                    • 121
                    Luke
                    Oh wow then i must of put both power and memory on the same one. Do you know which one is not constant power but works only when ignition is turned???
                    • StereoInstaller1
                      GAS
                      • 22679
                      ACC (Red on your deck) goes to VI/GY
                      Closing SOON!
                      • AndrewBird
                        The Mad Scientist
                        • 11897
                        I highly suggest you buy a test light. You can get them for like $3 and the answer to your question could have been found in minutes.
                        • StereoInstaller1
                          GAS
                          • 22679
                          Young Jedi, you learn well!
                          Closing SOON!
                          • AndrewBird
                            The Mad Scientist
                            • 11897
                            I've been using a test light since about age 4.
