Replacing stock tweeters
  • parkerbink
    • Jun 2004
    • 10138
    I want to put my new MB Quart tweeters in the stock location. I took the pod out and the original Nokia tweeter seems to be glued in. Since I don't want to mess anything up what advice can you guys gove me to remove them?
    Thanks
  • T.Dot E30
    • Mar 2004
    • 536
    Flat head screw driver and pry it out.
    Mine broke out perfectly and i glued in the new ones.
    • parkerbink
      • Jun 2004
      • 10138
      Thanks Done!
      • mgold
        • 709
        What did you have to do to remove the tweeter panels without breaking them. I'm not sure how they are secured.
        • DSchultz325e
          • Aug 2004
          • 1158
          AFAIK the tweeter sail panels are the same as the regular ones. If that is the case...they come out, it's just pretty difficult to do without snapping them if you don't have experience. They're only secured by 3 little tabs, each about 3/4 inch in from the corners. The tabs are also about 3/4 inch long, so it will take a little bit of work before they come loose. Don't tug at an angle, and eventually they will just pull straight off
          I retired my E30 for now...
          E46 323i
          David Schultz
