Tell me if this idea is feasable..
  • Kruzen
    • Mar 2004
    • 5603
    My v1 has a cigarette charger with two RJ-11 jacks on it, one for the v1 and 1 for another remove v1 device...
    I just got a phone and it uses micro usb to charge it (motorola) between 500 ma and 850ma for charging.
    Would it be possible to build a rj-11 to micro usb cable (or run it through adapters of some sort) and power the phone off of my v1 cigarette adapter?
    Who doesn't love a little BBQ?
    Griot's Garage at a Deep Discount
  • James Crivellone
    Head Janitor
    • 6305
    as long as the output voltage and current are sufficient, I don't see why not...
    • Kruzen
      • Mar 2004
      • 5603
      I've been searching online for a cable that's already prepped, can't seem to find a supplier even..
      Any problems on crimbing an RJ-11 cable into a micro USB connector since all that's running is straight power? Or is it more complex than that..
      • James Crivellone
        Head Janitor
        • 6305
        Any problems on crimping an RJ-11 cable into a micro USB connector since all that's running is straight power? Or is it more complex than that..
        Well remember USB is 5V +/- 1/2 volt, Some phones will take an increased voltage into the port, however I would step the voltage down from 12 to 5 (Assuming the V1 port outputs 12, I've never checked personally)
        • Kruzen
          • Mar 2004
          • 5603
          We'll have to chat about the best way to achieve what i'm trying to do... i'll give you a call later tonight. I'm horrible at electronics and remembering power demands :p
          • jeffw
            • 1087
            lowering voltage will prevent popped fuses which is what im doing on a daily basis it sucks nuts
