Just got my PPI 355CS compnents today
  • quickervicar
    • 1197
    #46
    Looks nice! Where did you source the grills?
    • stumble_t
      • Aug 2009
      • 759
      #47
      maximillian, but I'd give blunt a shout.
      [IMG]http://www.r3vlimited.com/board/
      • ed94r
        • Mar 2004
        • 382
        #48
        Originally posted by stumble_t
        First I snipped out the existing grill material from the kick panel then mounted the PPi's grill ring to the surface of the kick panel(out of the car of course) and used it as router guide to cut a precise hole for the mids.
        When you say "mounted the PPi's grill ring to the surface of the kick panel", do you mean "used as a template" or do you actually use/mount the PPI grill ring?
        I plan on using this install method for my PPI's mids.
        Ed
        1988 E30/S50...now with S52; Track
        1994 Miata R; ES Solo2
        1998 Lexus LX470; Wife (Slee'd anyway)
        2002 BMW 530i; A+ Commuter
        2002 BMW 325iT; Sport/Premium 5-speed
        2011 21' EconoTrailer
        • sennasixty8
          • Jan 2008
          • 346
          #49
          I'm curious about this too, bring your car out to the next local baye30 meet in san bruno this month, I wanna see that in person, and hear them too?
          Ed
          • stumble_t
            • Aug 2009
            • 759
            #50
            Ed
            Yes, I mounted the ring to the face of the panel only as a template. This provided a surface for the router bearing guide to trace, thereby cutting the correct size hole and keeping it perfectly round. After routing I removed the ring and had screw holes that would line up for the grill cover.
            I had to rotate the driver in the kick panel a few degrees to uncover the factory holes that need to be used to mount the grill cover. To mount the driver you will have to mark and drill 4 small holes(again the ring comes in handy for this) and use the little clips provided to fasten them. I'd suggest using a small piece of tape to hold 'em in place.
            I also used some slightly wider gasket tape I had. The stuff in the box was all dried out.
            • Dirtboy
              • 458
              #51
              Originally posted by twistednut
              This is how I gain room for excursion. The woofer is turned and screwed into the body at a 45 degree angle so the grill will screw directly into the original screw holes.
              So I mounted the tweets on the surface of some blanks with the angled cups. I also liked twistednut's use of the rear deck grills for the mids so I did that as well( thanks twistednut:up:)
              Here's a few pics
              It's a close fit with the glovebox but it definitely clears
              Part # for the grill is: 65131370803
              I used the long screws included with the ppi's to mount the grill.
              Those setups look nice. I plan on doing the same when I start my audio build.
              Nürburgring info
