Ok I have a 300 watt 4 channel amp running my 4 infinity refrence speakers in the car but I had to use Y-connectors to run my RCA cables since my headunit only has to outputs. Now If I wanted to hookup another amp that would be connected to subs how woul I go about doing this would I have to get another Y- connector. I don't really want to buy a new headunit right now with mroe outs since theres alot mreo important things I'd liek to invest in but I need to know If I can even run another amp into my shitty 2 output pioneer.
Hooking up subs to my headunit.
my last head unit which was a pioneer had two out puts also. they were for the subwoofer though. you should make sure you didnt hook the 4 infinity speakers to the sub output. Does the head unit have a wiring harness with purple,white,gray, and green(four channels to run front and rear speakers) wire sets? if so you can hook up another amp. You'll have to cut the connectors off of one side of the RCA cable/s and splice them to the corresponding channels to do it, then plug the end with the remaining connector/s into the amp. hope this helps. -
hmmmmmm whats inside those RCA cables??? wires maybe? 2 in each cable to be exact.Comment
lol
WTF ever ...i was trying to help. seemed to me like they were tryna find the cheapest route. sorry if my methods aren't the best ASSHOLE!!!! thanx for reading though.Originally posted by kencopperwheatJesus Christ... don't listen to that moron.Comment
Re: Hooking up subs to my headunit.
Quit messing with the stereo! When you get your car back in SA I'll help you out with the stereo and any other minor issues.Get that bauer running ....the semester is just arround the corner.Originally posted by bkelsey86Ok I have a 300 watt 4 channel amp running my 4 infinity refrence speakers in the car but I had to use Y-connectors to run my RCA cables since my headunit only has to outputs. Now If I wanted to hookup another amp that would be connected to subs how woul I go about doing this would I have to get another Y- connector. I don't really want to buy a new headunit right now with mroe outs since theres alot mreo important things I'd liek to invest in but I need to know If I can even run another amp into my shitty 2 output pioneer.Comment
Re: lol
someone's on the fast track to the first banination in a while.Originally posted by DEADZONER1WTF ever ...i was trying to help. seemed to me like they were tryna find the cheapest route. sorry if my methods aren't the best ASSHOLE!!!! thanx for reading though.Originally posted by kencopperwheatJesus Christ... don't listen to that moron.My mountains are better than yours.Comment
yeah i know it was harsh. I shouldn't have said that but I don't care for name calling.Comment
Hah tell that to about 99.957823% of the members on the boardOriginally posted by bkelsey86lets just all chill soemtimes people say wrong things doesn't make them a dumbass or anything.I retired my E30 for now...
E46 323i
David SchultzComment
OK, so let me suggest...
First, you CAN safely wire speaker outputs directly into RCA (line level) inputs, with only a tiny bit of magic involved, but let us not go there, OK?
bkelsey86, here is what you should check for first...does your amp have ANY switches that say anything like "INPUT MODE" or similar? Does it have 3 sets (6 total) RCA jacks? IF, failing that, do you live near a pawn shop?
Hit me back with a model number of your amp. I always recommend people run 3 sets of RCA's back, just so you dont have to re-do it later.
LukeComment
