Component Speaker help!
  • vtmatt
    • Jan 2010
    • 19
    Today I started the process of installing some 5 1/4 polk components, 6 1/2 rears, and nakamichi cd deck into my E30 85 318i. Everything turned on fine and worked well just a couple issues that I could use some advice on:
    - The drivers side kickpanel speaker would not fit back in with the crossover stored directly behind. I noticed some moisture issues in both doors and would prefer not to install the cross overs there. Any other suggestions that would look clean or not noticable?
    - HU worked great. Only issue is that when i turn off the ignition the settings reset every time. Not sure if i wired something incorrectly? Any advice?
    Thanks in advance for any help or guidance.
  • drumad
    • Aug 2009
    • 1700
    for your second issue... the HU is in effect turning off completely when you shut off the car. try to see if all your power leads are secure and correct
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • Massive Lee
      • Sep 2006
      • 6785
      SHU should be hot at all time.
      massivebrakes.com
      • dashboardmonkey
        FUCK YOUR WAFFLES
        • Jun 2008
        • 6158
        sounds like you have the constant and accessory wires switched
        -Andy
        • vtmatt
          • Jan 2010
          • 19
          Thanks..just fixed this morning and that was the case. To double check i checked with a voltmeter before switching...works great...now just have to figure out this crossover issue.
          • joeyvaz
            • Jan 2010
            • 35
            You can buy appropriately sized mylar balloons from a party store. Put the crossover in a balloon and tie a knot where the wires exit the balloon. This should protect them from being infiltrated with water. A little vaseline or grease at the wires exiting the balloon can't hurt.
            • Mless5
              • Jul 2006
              • 817
              One in the glove box, another under kickpanel below headlight switch.
              '96 328is
              '97 m3
              '04 zhp
