6button vs 13button obc wiring question
  • Jean
    • 18228
    Does anybody have a picture of the 6button vs. 13button obc wiring harness?
    Or just the 6button one, as I have a 13button obc wiring on hand.
    thanks
  • scottinAZ
    • Dec 2009
    • 1312
    I should have a copy on hand from when I sold my 6 button.
    They arent the best, but I have one of each
    13 button harness
    6 button harness
    hope this helps
    I saved 15% on my Bimmer parts by switching to ...
    • Jean
      • 18228
      Thank you! I picked up a 13 button from a parts car, thinking that maybe I'll add the OBC to my car but I don't think I am going to bother. I might add the 6 button though..
      • scottinAZ
        • Dec 2009
        • 1312
        its not hard to add. If you already have an OBC then the wiring to the temp sensor should already be there. other than that, its the same labor to install the 13 button as the 6 button. run the wiring harness, hook to gong, cluster, etc. all the "stuff" sholuld be there, except for the "code" function, and that isnt really desireable anyways (IMHO) as it is a point of failure that can leave you stranded.
        • aaron325ix
          • Jun 2007
          • 1489
          If youre going to add one, go with the 13 button. Adding a 6 button is like replacing your cracked dash with one that has that little seat belt light thingy on it.;)
          • iwantspeed
            • 3164
            can any one identify which color connector goes where.
            there are some that go towards the cluster
            door gong
            code box
            temp sensor
            and obviously the OBC
            Project
            Parts for Sale
            Feedback
            YouTube Channel
              • 34847
              it's all pretty obvious when you go to hook it up... all the connectors are color coded.
              • iwantspeed
                • 3164
                I found this article on how to do it.
                Project
                Parts for Sale
                Feedback
                YouTube Channel
