Reuse of window lock button
  • BeFunk
    • Jan 2010
    • 21
    Pretty sure this is a go for my amp install but wanted to put it out there just in case. Any one tried using a second window lock/button... thing, as a amp power cut off wired inline to the remote amp wire.
    Cant find a reason it would not work. The button/switch is marked for 12v 15a which is WAY over what the remote wire needs.
  • kronus
    • Apr 2008
    • 13028
    It will work, but why not just run a remote from the pin specifically put on your head unit to act as a remote switch?
    cars beep boop
    • BeFunk
      • Jan 2010
      • 21
      LOL I am talking about going from the head unit to the switch to what ever is on the other end. IE amp cluster, carPC, etc. More of a click hear to just have a normal radio kind of thing.
      It would not normally be an issue but between the little ears in the back seat and the person driving from the passenger seat i think it may be wise to rig such a switch.
      make a little more sense? :)
      • StereoInstaller1
        GAS
        • 22679
        I use them to turn on the AUX fan, or raise/lower the antenna
        Closing SOON!
        Thanks for 10 years of fun!
        • bimmerpirate
          • Feb 2007
          • 561
          I have mine wired to the pass door switch to turn on the dome lights without having to reach behind or across to the opposite side.
          • BeFunk
            • Jan 2010
            • 21
            why do i think I am going to have a dash full of these switches...
