mine has plastic covering where the tweeters would be, i believe it was an option, my question is if i by the tweeter pods, can i put in my own , also will i need to run my own wiring or are the wires there just plug and play tyia guys
318is Tweeter help....
Originally posted by ohthebaby View Postmine has plastic covering where the tweeters would be, i believe it was an option, my question is if i by the tweeter pods, can i put in my own , also will i need to run my own wiring or are the wires there just plug and play tyia guys
Sorta plug and play, do you have a manual of the wiring? if not just go to your local auto parts store or look for it on real OEM, it should clear things up for ya. ;)@IRON-E30 aka Edwin:D
Originally posted by StereoInstaller1 View PostWhy would you need a dremel at all?
The old tweets pop out, most all E30s are prewired for the tweets.
It really isn't a big deal at all.
Anyways, Luke is right it's not a big deal, just look for the connectors and you won't go wrong.@IRON-E30 aka Edwin:D
It's plug and play, but you must obviously have premium mids that have the crossover on them for the tweeter wires to connect to.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by IRON-E View PostI probably had some tweeters with super glue on them then 'cause in order for mine to pop out, I had to shave the surrounding part of the plastic and then I replaced them with some 800wts tweets.
Originally posted by StereoInstaller1 View PostNo, they are stuck on pretty good. If you grab a medium screwdriver and stick it between the tweeter and the housing, you can twist it in a few spots, the tweet will break free.
I ended up just grabbing the magnet with the slip-joint pliers from the toolkit and popped it out, separating the magnet and diaphram from the plastic face. Broke the speaker in half, basically.
If you put the screwdriver between the housing and the magnet, you'll just remove the magnet... You have to pry deeper between the housing and the tweeter itself.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
