Power antenna help
  • HarryPotter
    • Jan 2010
    • 3642
    Power antenna help
    My power antenna likes to work intermittently. The connector on top of it is shoddy at best. The connections are clean and been sprayed with electrical connector stuff. It's very annoying. It was working all day yesterday and towards the end of the day it stopped, and I gotta fuck with the connector to get it to go up or down. It works like a champ though when it is working.
    Any advice on getting this thing a better solid connection?
    I don't get what's up with the connection everything's tight and the connections are clean, and they only work in certain positions it's very odd. Maybe the si board is bad on the antenna? The motor is brand new.
    John F. Kennedy
  • getouth
    • Jan 2010
    • 3343
    I have the same problem....post when you get it figured out. Good Luck.
    FEEDBACK:
    http://www.r3vlimited.com/board/showthread.php?t=316212
    BMWCCA #398608
    IG @yagayo38
    "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
    • stumble_t
      • Aug 2009
      • 759
      Check the white wire at the back of the HU. I've also had older factory decks whose remote signals were intermittent and have crapped out.
      [IMG]http://www.r3vlimited.com/board/
