first time installing crossovers. where do i put them?
  • richardkeith97
    • 1693
    btw i've done tons of stereos but never dealt with a stock amp. just replacing decks and installing new speakers in stock locations. installed subs in all my vehicles with no problems.
    • richardkeith97
      • 1693
      the car came with an aftermarket stereo that didn't work. it was a sony. i removed it and all the wires for my new jvc were the same color so i just spiced them all together. behind the stereo is a serious rats nest. plugs that go to nothing and just looks like way more wires then needed.
      • dinanm3atl
        • Feb 2007
        • 7305
        In my experience both the E30 and E28 'premium' system with their amps are crap. When you hook up an aftermarket radio it almost immediately starts clipping. Bypassing it ASAP is the best thing you can do IMO.
        • StereoInstaller1
          GAS
          • 22679
          In my experience, very few people know how to properly interface it with an aftermarket deck.
          Believe it or not, 99% of the "pros" out there get it wrong...and have the exact same complaint you do.
          The issue is that the input stage is being overloaded by about 300%.
          If you leave the decks negative speaker disconnected and put chassis ground on the input grounds, it generally works great.
          oh yeah, and also recognize that BMW uses black stripe for rear positive...
          Seriously, you should hear one done right with all stock stuff. better than 90% of the aftermarket speakers out there.
          Closing SOON!
          Thanks for 10 years of fun!
          • accident
            • 7303
            where does the wire that goes further down the harness for the tweeters go? i found some premium fronts at the junk yard to replace the shitty pioneers the PO installed, and i plugged the tweeters into them and there's no sound :(
            Moral of this story?
            • StereoInstaller1
              GAS
              • 22679
              It goes a few inches past the other terminal. Look for a small blue plug.
              Closing SOON!
              • dinanm3atl
                • Feb 2007
                • 7305
                I am no 'pro' but the amp just seems like a turd. Trying to work with it seems like a waste. With that said I have never listened to one 'done right' so I am biased.
                • richardkeith97
                  • 1693
                  random ??. on my new aftermarket deck. for the speakers wires. is a line on the wire postive or negative?
                  • StereoInstaller1
                    GAS
                    • 22679
                    On most all aftermarket decks there is a standardized color code...but once again I am having to ask what you have...seeems if you are asking technical questions you should supply ALL the info you can.
                    Soooo...what deck do you have?
                    Closing SOON!
                    • richardkeith97
                      • 1693
                      jvc kd36 or sumtin like that. i lookeed in the book and it doesn't say. i know usually the wire with a black line is ground?
                      • richardkeith97
                        • 1693
                        all done i just ran new wires. sounds awesome
                        • StereoInstaller1
                          GAS
                          • 22679
                          Hooray!
                          Closing SOON!
                          • rountreesj
                            • Sep 2009
                            • 84
                            so look, should i run my own ground for the head unit. and then separately ground EACH speaker?
