tach and mpg not working help!
WTB late model, anywhere on the east coast will go as far west as Texas for the right car at the right price. 5 speed 6cyl only.
"She may not look like much, but she's got it where it counts, kid." - Han Solo -
It sounds like the SI board itself, not the batteries although I believe RatShack has the batteries you're looking for.
Usually, the SI board has a solder joint fail so when you smack the dash, it might make it work for a while.
That's also a good way to put a crack in your dash.sigpic
1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
Yeah, your coolant level sensor is no good.I have this same problem on my 88 ix, and the red and yellow oil service lights stay on all the time, whether the car is off or on.
Also, not to get off track but my coolant light on the overhead stays on whenever the car is on, but I am not overheating and I have a good coolant level. Any ideas on this?
About $20.00 and easy to replace.
I believe there is a way to jump the wires with a paper clip to test it, but you would have to do a search.
Either way, easy, inexpensive fix.
Do you have a MultiMeter and a Bentley E30 repair manual?
If not, get both as it will save you a ton of time.sigpic
Here's how I tested it: I held the bobber up on the level sensor with it out of the coolant. It fixed it, so I glued the bobber to the top of the sensor. The "fix" worked, but now I'll obviously have to check my own coolant level.Yeah, your coolant level sensor is no good.
What I believe happens is, the bobber gets old and as it soaks in the coolant, becomes more dense and loses its buoyancy.WTB late model, anywhere on the east coast will go as far west as Texas for the right car at the right price. 5 speed 6cyl only.
"She may not look like much, but she's got it where it counts, kid." - Han SoloComment
Problem one: si board/batteries
Problem two: replace your coolant level sensor
To the op: pull your gauge cluster and take it apart, clean all the contacts of the boards and the gauges (all the pins and the sockets they go into). Then when you reinstall, make sure the two grounding nuts on the back of the cluster are on tight. Doing that cured all of my cluster issues in my wife's '87 325.
Where at in TX are you? Im north of Dallas.1990 325is
m52b28
3.73lsd
g260 (1987 325is 5spd tranny)Comment
yesMtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
bah! good to hear your tach/mpg is working after an SI battery replacement. i put in a new SI battery, new board, even took a new tach and still no dice. my next step is resoldering the connection on the actual cluster board. When it's warm out, my tach/mpg works just fine so, i'll probably be lazy and forget about it until the first day it stops working.| '89 M3 | '93 M5 | '03 X5 4.6is | '03 325i | '87 190e 2.3-16 |Comment
I don't think he said it fixed the mpg...fixed the tach only.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
