Best 2 or 3 way mids for the money?
  • reelizmpro
    • 9537
    Stock speakers in a convertible are 4.25" right? and 5.25" fit perfectly, at least they do in my M3. Just want to make sure the verts are the same. I need to get some speakers but don't want to spend too much...maybe $50 a pair. I'm thinking Polk Audio, Rockford Fosgate, Infinity, Boston Acoustics. Been a while since I bought speakers. Thanks.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
  • StereoInstaller1
    GAS
    • 22679
    Verts are 5.25 also.
    The rears are a bitch. Depth is an issue, as is magnet diameter, but far more important is tweeter protrusion. I made my own coax speakers out of a set of premium sounds.
    Closing SOON!
    Thanks for 10 years of fun!
    • reelizmpro
      • 9537
      Just to update my thread...
      Just installed these 5.25" in the rear of my vert. They barely fit with the large magnet size. I read the stock speaker is about 2.25" deep, the Alpines I used were about 2" deep but with a much larger magnet. I went with these Alpine's mainly because they were cheap $30 shipped on ebay and matched my headunit. As you might imagine, they sound much better than the stock rear speakers. They really fill the sound in back there. Still debating if I should get a small in cabin subwoofer.
      88 M3 - LACHSSILBER
      • Heysüß
        • 911
        sweet. I'm also looking to just freshen up the sound nothing too fancy or heavy just trying to replace the stock speakers.
        You think these would go along ok without needing an amp? (I'm looking to get a pioneer or alpine headunit along with fresh speakers all around)
        09/1989 325i 4 Door
        +M30 Swap
        +Z3 Steering Rack
        • Heysüß
          • 911
          09/1989 325i 4 Door
          +M30 Swap
          +Z3 Steering Rack
          • mach schnell
            • Apr 2008
            • 1059
            Do these Alpine's just drop in and hook up?
            Or do you have to run new wiring?
            • soupiemelody
              • 188
              They drop right in with the existing wiring
              1991 318i Past
              1990 325ic Past
              1998 540i/6 Past
              1988 325ic Present
              1998 M3 Present
              2000 M5 Present
              • mach schnell
                • Apr 2008
                • 1059
                Awesome, thanks.
                What about for the front speakers? Can you use these too?
                • soupiemelody
                  • 188
                  Awesome, thanks.
                  yes they can be used as there is more clearance, but i would recommend getting a component set and mount the woofer in the kick panel and the tweeter in tweeter pod
                  1991 318i Past
                  1990 325ic Past
                  1998 540i/6 Past
                  1988 325ic Present
                  1998 M3 Present
                  2000 M5 Present
                  • mach schnell
                    • Apr 2008
                    • 1059
                    I was hoping to use speakers that will drop in and won't require new wiring etc. Can I do that with a component set?
                    • soupiemelody
                      • 188
                      yes it drop right in, once your car already has the premium sound with the tweeter pods otherwise just get 4 of the alpines
                      1991 318i Past
                      1990 325ic Past
                      1998 540i/6 Past
                      1988 325ic Present
                      1998 M3 Present
                      2000 M5 Present
                      • antil33t
                        • 176
                        I have the 6.5" version of those in my rear, and the 6.5" component in the front doors.
                        Good speakers, MUCH better with an Amp. 10x better with an Amp over the headunit.
                        a sub would be the go, in the long run if you listen to it loudish the speakers aren't really "bassy"
                        • soupiemelody
                          • 188
                          does the 6.5 mount in the kick panel without modifications?
                          1991 318i Past
                          1990 325ic Past
                          1998 540i/6 Past
                          1988 325ic Present
                          1998 M3 Present
                          2000 M5 Present
                          • antil33t
                            • 176
                            Negative, they are very shallow the TypeS 6.5" are.
                            you may get away with a slight spacer?
                            • mach schnell
                              • Apr 2008
                              • 1059
                              So these Alpine SPS-500's should make a noticeable improvement, if you add them in four locations, I would think...?
