Lemme say this clearly with great emphasis: an LC6 is a waste of time on this deck.
The 7 I can see as it does much more, but even that is pointless. AUX in can be done a lot better than that.
I have done several installs using these decks, never have I had ANY noise issue, and the noise floor of the system is stunningly low too, because the gains are generally near the bottom of the range.
The 6XS is of course a completely different animal, as it is a crossover, not just an adapter.
If you can afford the money to get an LC6, get better amps instead. Aim for "/ series" JLs at a minimum, but aim for Zapco, or better still, ARC Audio.
And Pierre, you have a solid grip on it. Feed these RCAs into any decent amp, you will be fine. RCA plugs can be bought at Radio Shack, they have some decent ones.
