Does a Z4 antenna swap easily into E30s?
  • herbivor
    • Apr 2009
    • 1420
    I don't have a power antenna or any antenna for that matter. Will a short Z4 antenna fit directly into an E30?
  • Dirtboy
    • 458
    yup
    Nürburgring info
    • StereoInstaller1
      GAS
      • 22679
      you still need the E30 grommet
      Closing SOON!
      Thanks for 10 years of fun!
      • 36brua
        • 689
        or same thing here
        My CA legal M60 swap
        The happening in our garage
        • MattM
          • Apr 2009
          • 931
          no, you need a Z4 grommet(or E36ti ones work too). i did this recently, great swap, took all of 5 minutes, 2 to pull the antenna from the Z4, .5 to walk over to my car, and 2.5 to install in mine
          Full Build Thread Here
          • StereoInstaller1
            GAS
            • 22679
            I did it with an E30 grommet, so both work...but you do absolutely need a grommet...
            So Matt, how is your reception? Does AM still work well?
            Closing SOON!
            • MattM
              • Apr 2009
              • 931
              hmm, thats interesting, my E30 grommet was WAY to large...
              anyways, my reception is stronger then my old antenna, honestly i hardly ever switch over to AM, so i cant compare, but FM is great!
              • Jean
                • 18228
                Grrr, I need to do this...
                • jquirit
                  • Dec 2009
                  • 114
                  My only gotcha with this mod (used a 318ti antenna base + PepBoy special antenna) is that it's angled a bit out of vertical. I need to make a little brace to true it up.
                  Outside of that, seems to get very strong signal. Pretty much plug and play.
                  Though, the grommet thing I'm not too sure about. When I did mine I had to use a 318ti grommet as the stock one had a far too large hole.
                  • bmwman91
                    • Oct 2004
                    • 3134
                    Good info! My antenna has been busted forever!
                    Transaction Feedback: LINK
                    • bmwstephen
                      • 2463
                      any pics of it installed?
                      • plotfi
                        • Mar 2012
                        • 394
                        Anyone done this? It seems like they are referring to Z3 not Z4!
                        feedback http://www.r3vlimited.com/board/show...32#post4540332
                        1972 2002 Chamonix
                        1984 325e Hennarot (M20B31)
                        1988 325is Bronzite Time Capsule
                        • e30_world
                          • Aug 2014
                          • 586
                          Who uses AM hahahha! But really! Wondering how the reception is on these. Mine doesn't go up anymore and I'm on a stock radio so mine simply blows. Is there a big difference between the z3 and z4?
                          F80 M3 Alpine
                          E10 Fjord Blue 2002
                          E28 Blackish 535i
                          E21 Silver 320i
                          Disco1 98 4.6
                          E30 Cirrus coupe S50 SOLD
                          E30 325i SOLD
                          E30 Alpine 325i vert Euro spec SOLD
                          E30 Alpine coupe 325is SOLD
                          • plotfi
                            • Mar 2012
                            • 394
                            Not sure if anyone has tried installing z4 antenna
                            1972 2002 Chamonix
                            • g.ruff561
                              • 1263
                              E36 vert antenna works just as well. Same cost in parts and I'm sure the parts are the same, they just supersede to the Z4/ Z3 model. I have this mod on both my cars. Black to ground, Red female hot to male antenna module base. White is taped or heat shrunk to cover wire and avoid grounding to chassis and zip tied out of the way. Enjoy..... Cheers!
                              G.
