Changing the backlights on my instrument cluster
  • BrooklynMW
    • 1263
    Would like to do it. Got the lights, but don't know how to do it.
    Easy? Would someone like to give me a list of what to do?
    Thanks!
    '87 325i "Chewey" (RIP, my beloved)
    current:
    '01 e46 325iT "Dot" - #datwagonlife
    '87 e30 325i "Tui" - she has her mother's eyes
  • ak-
    • 12422
    What kind of steering wheel do you have?
    Need help removing the cluster or just lights?
    1991 325iS turbo
    • BrooklynMW
      • 1263
      This kind:
      I think the whole cluster. I would have to remove it to change the backlights, correct? The right side light is out. the one that lights the temp gauge and tach. I figured, while I'm in there, I'd change both.
      I found the 2 little screws on top, and removed them, but realized I probably shouldn't try to pull the thing out until I knew what I was doing.
      current:
      • rooster
        • Jan 2009
        • 80
        damnnn!! check out the blonde in the black dress
        jag
        • rountreesj
          • Sep 2009
          • 84
          good observation...who needs dash lights!?
          • BrooklynMW
            • 1263
            Ok, fellas. I promise I'll post more pictures of blondes in black dresses if someone would just help me learn how to change my lights!
            current:
            • george graves
              • 20003
              That's not a blond.
              You need to remove the cluster. To do that you need to remove the wheel.
              Originally posted by Matt-B
              • BrooklynMW
                • 1263
                Ok, tough to do? Easy? I just ordered the Bentley e30 Manual. Will I find such projects in this wonderful and mysterious book I hear so much about?
                current:
                • george graves
                  • 20003
                  I don't have that steering wheel. But I bet you pry off the center button, under it will be a 22mm nut. Remove nut, and washer. To remove the wheel you'll need the key to unlock it. The rest is just screws and stuff. Pull the cluser out a bit, carefully work it out of the dash. Be careful of the upper cluster mounting arms. They break stupid easily. The back of the cluster has 3 main connections. Pull the cluster out, get a screwdriver under the black clip, and then pry it up. Then you can unplug the connections. There'll be on wire attached to the green socket. Remove that. Cluster should be free now.
                  • BrooklynMW
                    • 1263
                    Thanks, sounds like a hefty job. I will wait till I have a nice long day off.
                    current:
                    • george graves
                      • 20003
                      It's 15-30 mins.
                      • deekay
                        • 28
                        u might be able to manuver the cluster out thru the steering wheel just give it a shot try tilting and turning it if not i beleave its a 22mm nut and some wiggling to get the steering wheel off shouldn't take u more then an hour to do the entire thing.
                        • iwantspeed
                          • 3164
                          this will walk you through the process of removing the cluster.
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • BrooklynMW
                            • 1263
                            http://home.comcast.net/~cdeegan9/da...shboard_1.html
                            This is very helpful. Thanks! I plan on doing the job this saturday, and will definitely be prinitng this out, and keeping it along side me
                            current:
                            • nadodude111
                              • Jul 2009
                              • 432
                              I can remove the cluster and put it back in 15 minutes without removing my airbag steering wheel. It's really easy.
                              1992 325i Convertible
