Infinity Basslink
  • reelizmpro
    • 9526
    Infinity Basslink
    Anyone have experience with Infinity Basslink? It has pretty good reviews.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
  • Eurospec
    • 2613
    Curious if you ever got around to buying this. I was planning on picking one up based on the reviews I've read and would like to know what your thoughts were.
    • StereoInstaller1
      GAS
      • 22679
      I have never heard one, but an installer buddy of mine said they were pretty damned impressive for what they are.
      Closing SOON!
      Thanks for 10 years of fun!
      • reelizmpro
        • 9526
        Never got one because they are expensive. Just went with a used traditional sep sub and amp. Didn't know if I could trust an all in one system anyway.
        88 M3 - LACHSSILBER
        • pegase747
          • Jul 2006
          • 279
          I might want to try that as I really dont want to butcher anything in my Alpina.
          Also I have the Alpina additional fuel tank installad, so my trunk space is already reduced...
          Went to read a few reviews, and looks like it is good value for monney.
          Also the bass volume switch can probably be integrated nicely in a standard dash swith location above the head unit....
          Pierre
          1988 E30 ALPINA B3 2.7 #224/257 Made in Buchloe
          see more : http://www.r3vlimited.com/board/showthread.php?t=71686&referrerid=12460
          • StereoInstaller1
            GAS
            • 22679
            Pierre, does your alpina have a rear battery? It is a late model, correct?
            Closing SOON!
            • pegase747
              • Jul 2006
              • 279
              Luke,
              Yes, rear battery in rear right compartment. late model from Feb 1988.
              The Alpina fuel tank sits basically where you make people install your box.
              So a box could be designed, but it would have to be lower.
              Also I really am not a big bass fan, but I just want to add bass of what I will do on my B3.
              Reading the basslink review, I think that will fit the bill nicely.
              Can be found for around Euros 150 here used.
              Also this little bass volume controle potentiometer can probably be well integrated above the Hu in one of the blank switch !
              What is your professional point of view ?
              Pierre
              • BMW_TUNER
                • Jul 2006
                • 1386
                I had one in a grand Cherokee. It was good in a gc but is sucks compared to a luke box
                1989 332IS -S-Fiddy Four-Some weight removed.
                5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
                • buffalino
                  • Jun 2010
                  • 61
                  i got 1 in my cabrio,,, not bad at all i paid 150 euros for it,, im inpressed,,,
                  • bad_azz_bmr
                    • Sep 2004
                    • 433
                    Interesting, where did you mount it in the cab?
                    • M-technik-3
                      • 18946
                      Got a used bigger amp one it's great for me just wanted some additional bass not a rattle maker. It also comes out of the car quickly so i like it and at just over a cubic foot it's great.
                      • aworthybrother
                        • May 2007
                        • 899
                        I have basslink in my cabrio. It works just the way I like it. I placed mine in the trunk where the battery should be. I still have my whole trunk space.
                        • SnoqualmieE30
                          • Feb 2011
                          • 18
                          I have a basslink in my '90 325i. I couldn't find anything as far as mounting it in the trunk. I ended up mounting it to a piece of plywood with the trunk carpet sandwiched between the wood and sub so it wouldn't slide around. Does anyone know how they're supposed to be mounted in the E30? Do you have to drill through the metal trunk floor?
                          • pegase747
                            • Jul 2006
                            • 279
                            I think fixing through the floor or the back seat will be fine.
                            How do you like the sound of the basslink in the 2-door trunk ?
                            Pierre
                            • ck_taft325is
                              • Sep 2007
                              • 6880
                              Rear seat ski-hole pass thru. It's a sheet of metal, dead center of the seat. Smack it. Seriously. It'll pop the tiny spot welds and you can bend it out like openning a can of tuna.
                              Need a part? PM me.
