converting from mechanical to digital speedo
  • b*saint
    • 3794
    Anyone have a direction they can point me in for this?
    Ma che cazzo state dicendo? :|
  • bmwman91
    • Oct 2004
    • 3130
    How good are you with mixed-signal systems? If you are comfortable with them, just find any LED/LCD display that will fit cleanly & go from there. You might even be able to pull a digital cluster from some early-mid 90's Ford's & use that.
    There are some really expensive pre-built digital clusters out there by racing hardware companies. Those suckers cost more than an E30 though.
    Transaction Feedback: LINK
    • castros
      • 828
      there is a company out here in north hollywood that sell's vdo conversion gauges, i'll see if i can get you contact info.
      www.CASTROMOTORSPORT.com
      Castro Motorsport
      12600 Sherman Way, Unit C
      North Hollywood, CA 91605
      818-765-3606
      Follow Castro's on Facebook:
      http://www.facebook.com/pages/Castro...02411516506828
      Follow Castro's on Instagram:
      http://instagram.com/castromotorsport#
      • b*saint
        • 3794
        No Im completely converting to digital. Its for my bike, not my car.
        If you can get my the vdo info, that'd be great unless its meant for a bmw.
        • castros
          • 828
          No their just gauges for anything, not only for bmw's for as soon as i find you the info i'll give it to you. They do have digital gauges as well.
          Castro Motorsport
          818-765-3606
          • bmwman91
            • Oct 2004
            • 3130
            Interesting...I want to see what is available as well.
            • psyber_0ptix
              • 904
              my bike is normally cable driven; i got an acewell gauge which uses a magnet on the rotor bolt and a hals type sensor mounted on the forks ????
              other aftermarket gauge's use a smiliar method
              Originally posted by FredK
              However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
              My year in Germany
              Feedback
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Dakota Digital.
                EDIT: Linky http://www.dakotadigital.com/index.cfm
                • b*saint
                  • 3794
                  Those gauges have a reputation?
                  Im thinking of machining a custom cover for my output sprocket and mounting a sensor to generate a wave off of the sprocket. Only thing I am worried about is a lot of chain shit.
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    I don't mean their gauges, I mean their sender/converter stuff. You can use VDO or whatever you want...
                    • ogchristopher
                      • 54
                      pics
                      • xLegendOZWest
                        • Jan 2009
                        • 406
                        what about the gauges? are they any good?
                        Live Fast. Drive Faster.
                        "Nitrous is like a hot girl with an STD... :)
                        You wanna hit it, but your afraid of the consequences :(
                        • b*saint
                          • 3794
                          Im thinking any inductive sensor will work right? As long as it is an on/off signal produced.
