Alright my gauges went out the other night. Everything except the speedo went out, along with my power mirrors, and everything heater/ac related. My abs light in the dash turned on same time as the battery light, and when I go to drive my car when I start crawling the engine dies. Fuse 10 is reading high on the amps to the point where the alligator clips get warm and the ohms resistance jumps from 1.5 to 50 when I shake the car. Help?
Clusterfucked gauges
You've got a short under the dash, sounds like. Mine was the power wire to the check engine light bouncing around and shorting against the ABS unit. At 50 amps of drain it's liable to have cooked some wiring, so take a peek and look for melted insulation, you're bound to find some.
Originally posted by e30Matt View PostYou've got a short under the dash, sounds like. Mine was the power wire to the check engine light bouncing around and shorting against the ABS unit. At 50 amps of drain it's liable to have cooked some wiring, so take a peek and look for melted insulation, you're bound to find some.Jah bless! :pimp:
i have the exact same problem rite now on my 91 318is, except fuse #10 keeps blowing out every 10min of driving. i tried turning the key on to start position and letting the car sit for awhile(not running), 3 hours later the fuse was still good, started it up and drove around for 10 min or so and bam, gauges all went dead, no heater controls etc. if you look up fuse #10 in bentley manual, that mofo powers alotta shit, including idle control and fuel delivery...
i got under my dash, couldnt see any burnt wires, gonna be a PITALast edited by golde30; 06-10-2010, 06:09 PM.IG: @Baye30
Originally posted by golde30 View Posti have the exact same problem rite now on my 91 318is, except fuse #10 keeps blowing out every 10min of driving. i tried turning the key on to start position and letting the car sit for awhile(not running), 3 hours later the fuse was still good, started it up and drove around for 10 min or so and bam, gauges all went dead, no heater controls etc. if you look up fuse #10 in bentley manual, that mofo powers alotta shit, including idle control and fuel delivery...
i got under my dash, couldnt see any burnt wires, gonna be a PITAJah bless! :pimp:
