do i need this????
  • e30 gangsta
    • 3877
    do i need this????
    crutchfeild says i should purchase this when installing a head unit in my bmw. What do yall think?
    this is the headunit i want.
    any help would be good seeing as im a complete noob.
  • Jordan
    • 12916
    No. You need to rewire your whole car, not install a crappy adapter.
    https://mtechniqueabs.com/
    • e30 gangsta
      • 3877
      great thanks for the info. Any write up on how to rewire the car?
      • DEV0 E30
        • Oct 2004
        • 8892
        @ Ryan Stewart's Site.
        • e30 gangsta
          • 3877
          thanks
          • DarkWing6
            • Apr 2004
            • 7144
            Originally posted by eightyfoure
            great write-up
            • thumper3ld
              • Apr 2005
              • 84
              Just out of curiosity, why would you need to rewire the whole car just to install a head unit?
              • DEV0 E30
                • Oct 2004
                • 8892
                Jordan is a purist.
                It's best to do, therefore you have a clean all fresh system that isn't jimmy rigged or outdated. (I pulled out speaker wire that looked like it had been eaten by a mouse.)
                • bkelsey86
                  • 1173
                  plus most the tiem the stock wire can't handle the added power and will aid in distortion.
                  • jajou318
                    • Jan 2005
                    • 1023
                    :oops: I didn't re-wire....
                    • BMW BMXER
                      • 2325
                      Stock wiring is also common ground. Aftermarket decks to not like this.
                      Sold it.
                      • Bimmerfanatik
                        • May 2004
                        • 5349
                        Jordan is a purist.
                        Jordan may be a purist, but that's about as close to a new E30 from the ground up as you can get (mine will be similar once I finally finish it!)
                        Being anal is one thing. But there's a reason for it all. Do it right or don't do it at all. That's my opinion.
                        If you want the best results, rewire. The 20 year old wiring was never designed to handle the power output of new decks today, and it makes for a nice clean setup with updated wiring. It's worth the extra effort.
                        • thumper3ld
                          • Apr 2005
                          • 84
                          I can understand people doing it for newness sake, some people are just like that and there's nothing wrong with that. But stock wiring not able to take the power of new decks, how much more power do you guys think the stock radio puts out? figure most aftermarket radios are about 50 watts peak and about 20-22 watts rms. Thats not that much more then stock radios. If anything stock radio maybe half that but the wiring should hold up. Now if you decide to amplify the speakers, then thats another story, but then you'd be running new wiring anyway because the amp does not sit behind the dash. My point, if you connect everything correctly to the stock wiring and it works, then i'd leave it.
                          • Bimmerfanatik
                            • May 2004
                            • 5349
                            Or, if you're dealing with high end stuff, like Alpine, they specifically request a seperate new wire for power straight from the fusebox.
                            Now, if your post above refers only to speaker wiring, I suppose I could agree with you, but the wiring in my car is brittle, has wear - which could lead to shorts, and fry a channel in your radio - ask me how I know.
                            • thumper3ld
                              • Apr 2005
                              • 84
                              If your head unit states you should, then i agree, run a new power wire. The reason why I mentioned about speaker wiring was cuz people mentioned head unit output. You do however, bring up a good point about changing the speaker wiring if it does look frail and worn. Mine appeared to be fine and I was not having problems speaker wise with my previous head unit so I opted to not change it.
