Anti-lock light
  • ethrtyiS
    • 8147
    Anti-lock light
    Alright so here's my problem, not sure if its supposed to be like this or what but, my Anti-Lock light is always on, it never turns off, is it supposed to be on, or do I have a dash problem? I'm so :crazy:
    「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
    「my feedback thread」
  • Sagaris
    • Sep 2009
    • 2243
    Not supposed to stay on. See if you can a patch of dirt to check the ABS on. If it works then thats good, maybe something is going on with the cluster. If not: Check to make sure the wiring on the wheel speed sensors is intact, someone may have mistaken the ABS wheel speed sensor for the brake pad replacement indicator wiring and went crazy with the snips. If the wiring looks good then it is possible that the wheel speed sensors are dirty or misaligned. They can be cleaned off with brake cleaner if they have road grime caked on them. Anything beyond this would probably be an ABS controller issue.
    • ethrtyiS
      • 8147
      Where can I go abouts finding this speed sensors wiring? I'm a total nub at wiring issues. It looks like the po did a hack job with the stereo and an after market alarm of some sort that isn't hooked up?
      • Sagaris
        • Sep 2009
        • 2243
        Remove the driver side wheel (not required but it makes it a lot more obvious to see if you dont know what you are looking for) There will be 2 sets of wires running from the brake caliper assembly, clipped into the strut housing, then through a grommet in the fenderwell into the engine compartment. Just a few inches from the grommet inside the engine bay there should be a white/yellow connector. This is for the ABS wheel speed sensor. Some people unplug that (theres one on each side) with the belef that it is the brake pad replacement indicator. Check to make sure that its plugged in, that there is no corrosion inside the connector, and that the wires arent cut/broken anywhere all the way to the sensor.
        • ethrtyiS
          • 8147
          Awesome, I'll do this tomorrow and take a look at it. Will give you an update with how it went. Thanks!
          • ethrtyiS
            • 8147
            Hey Sagaris, so I checked a while back on those two wires. I followed one to a little fuse box type thing with 3 relay fuses and the other one seemed to just go into normal fuse box or into the firewall. That first wire (that went to the 3 relay fuses) was bare, the black coating was coming off of it and it was leaving 2 wires exposed (black + red, I believe). Not sure if maybe the fuse relay is bad or not. Is that what I was supposed to keep an eye out for? Or am I completely retarded.
