Mounting Amps Unpside down
  • CiLK WuRM
    • 371
    How detrimental is this? I see Mike Swahle mounted a Class A/B infinty amp upside down in his M3, but for amps such as class D, how much of a problem is heat soak, etc?
  • Schnell 318
    • 567
    sholdnt be too much of a problem, unless its a really high powered amp that gets very hot.
    the heat from the amp will rise into the curcut board instead of the metal top of the amp so it might run hotter
    • BMW BMXER
      • 2325
      Bad. Avoid it. The heat sinks won't work effectivley upside down.
      Thats the common theroy anyway.
      Sold it.
      • Inspar8r
        • 301
        Normally it's bad, but some people get away with it.
        Lets put it this way:
        Mounting amps upside down is NOT a Best Practice.
        Nick
        87 325 5MT
        02 IS300 5MT
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          So, did they fry?
          • bmwman91
            • Oct 2004
            • 3130
            It depends on the amp. If the sides of the amp are big heat sinks then it won't matter too much. The MBQuart amp I put upside down also had vent holes in the bottom, so with them on the top now the hot air should get out of the chassis more easily. The PCB was on the top too, so not the heat rises from that with it on the bottom now.
            See if you can get a look inside.
            Transaction Feedback: LINK
            • dashboardmonkey
              FUCK YOUR WAFFLES
              • Jun 2008
              • 6158
              dont do it, unless you like replacing/fixing them
              -Andy
              • StereoInstaller1
                GAS
                • 22679
                Why not mount them upside right, hanging from brackets?
                You can buy cheap tubing at Home depot or a hobby store, cut lengths so that the amps have like 1" of clearance and shoot screws through the tube into the underside of the rear deck.
                You will of course need some damn long screws, but WTF, right?
                Closing SOON!
                Thanks for 10 years of fun!
