Good source for switched 12V, 5A draw
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    I need a good source for 5A for my new Spal fan to run on low speed at all times. What's a good place to tap in to? Or would it be better to use a relay? If so, what's a good signal wire to use?
    Thanks R3v,
    You mechanically-inclined yet electrically-retarded fan,
    CorvallisBMW
  • CorvallisBMW
    • 13039
    Anyone?
    • kronus
      • Apr 2008
      • 13029
      Use a relay, tap off the alternator red wire. 5A is kind of scratching at the limit for stock wiring. (nothing on the switched subcircuit draws nearly that much by itself)
      cars beep boop
      • Danny
        • 14216
        I pulled mineout of the main relay.
        • antil33t
          • 176
          Would use a relay, Definately run it off somewhere that can supply more than 5A, since motors on start up can use more than 200% their nominal power rate.
          • CorvallisBMW
            • 13039
            Which one is the main?
            Good point. Relay it is! Easy to get power off the alternator, I just need a signal wire.
            • KenC
              King of Kegstands
              • 14396
              One of the wires on the radiator thermoswitch is constant switched 12V. Grab power for the relay on the dist block like mine. There is a good chassis ground up there too.
              Originally posted by Gruelius
