aux fan help needed.
  • Unearth078
    • May 2008
    • 2623
    using a Bosch 4 pin relay, i am trying to get the fan to kick on high, when the low temp thresh hold is hit on a e36 m42 rad switch. I have done all my testing by jumping the gn/bk and bk pins on the temperature switch.
    I have given up for tonight due to finding out my switched 12v is staying on after the motor. the fan kicks on when turning off the motor.
    If i find the correct switched 12v should i be in business?
    Thanks
    Mike
    Originally posted by Lof8
    4 doors allow you to transport more whores.
    therefore, their value is much greater.
    Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
  • DaveSmed
    • Apr 2007
    • 1407
    Pin 86 is incorrect. Make it a ground. Or, if you <3 DIN standards/have a relay with a built in diode, do that and swap 85 and 86, making 85 the ground and 86 from C113
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • StereoInstaller1
      GAS
      • 22679
      Lotta grief for nothing.
      Wire the damn Spal with the stock wires, swap low and high on the radiator switch (leaving the stock low unused) and you are done.
      Closing SOON!
      Thanks for 10 years of fun!
      • Unearth078
        • May 2008
        • 2623
        i see i over analyzed this. thanks man! with a second set of eyes it all makes sense.
