won't start, starter is good
  • graffeedy5
    • 106
    Car won't start. Starter tested good and fired right up, no noise whatsoever when I turn the key.
  • ttrousdell
    • Nov 2009
    • 1770
    check fuel pump, check for spark as coil, check that sensors are all good. my cps shorted out and fried the ecu so i had the starter engaging and nothing else.
    The Build:
    • KenC
      King of Kegstands
      • 14396
      You're not getting power to the starter then. There is a dedicated power line that goes to it that comes from the power block on the firewall... make sure that all of your connections are solid there.
      Originally posted by Gruelius
      • graffeedy5
        • 106
        It push starts right away, so I don't think it's the fuel pump. I'll try the power to the starter. There's a number pad with a red and green light to the left of the steering wheel, doesn't say anything on it, haven't touched it since I've gotten the car. But the red light is lit and the green light is on. Could it be a security system or something?
        • ttrousdell
          • Nov 2009
          • 1770
          ok so the starter worked when bench tested but not in car. make sure all the grounds on the engine are good. there is bout 4 wires that hook up to it. make sure they are in the right spots. double check grounds is important
          The Build:
          • KenC
            King of Kegstands
            • 14396
            Who knows... that's definitely not stock.
            • DaveSmed
              • Apr 2007
              • 1407
              Odds are that's your problem.
              Luckily the starter circuit is super simple, so it should be easy to fix.
              -Dave
              2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
              Need some help figuring out the ETM?
              • graffeedy5
                • 106
                Took out that number panel and reconnected the circuit without it and it started first try.
                • TheEtaUnderdog
                  • Jun 2007
                  • 841
                  sounds like you flux capacitor was broken :D
                  Are you kidding me? That nerd doesn't even know how his dick works, let alone a car.
                  • graffeedy5
                    • 106
                    and now my low beams don't work haha, pissing people off driving with my high beams on.
