Sub not working
  • jasonsnoddy
    • 1900
    Sub not working
    so, im all excited. i have my sub, lukebox, amp, yadda yadda yadda.
    shits ll hooked up, not working.
    amp is getting power
    tested spare set of audio cables
    remote wire is good
    i guess maybe im hooking up the sub wrong?
    its connected to the sub channel of this amp:
    and this sub
    http://www.amazon.com/Infinity-Refer.../dp/B0028ARP1W
    ive tried wiring
    -__________-__________-
    and
    -___________-
    -____________+ on sub
    if that makes any sense.
    help?
    Originally posted by stewie30luvr
    ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
    Originally posted by JakeP
    with a coathanger
  • IminDiegoTriick
    • Oct 2009
    • 1564
    Have you tried checking the coil within the subwoofer & testing it. I had a JLw3 that would not work and I found that one of the terminals had a cut leading to the coil which explained why it was not thumping.
    Fast life fuck slow..Low life for life
    Let the mix flow..Let the night flow
    I'm so gone ✗ ♥ O
    • jasonsnoddy
      • 1900
      that something you can check visually? i have the sub in my lap right now and cant see anything out of place.
      with a coathanger
      • IminDiegoTriick
        • Oct 2009
        • 1564
        I have that very sub in my lap as well and you can see the positive and negative terminals on both sides connected to the coil
        I'm so gone ✗ ♥ O
        • StereoInstaller1
          GAS
          • 22679
          Check the input mode switch on the amp.
          Grab a different speaker to test with
          Use all positives together, and all negatives together: both woofer "+" to the + on the amp,
          Both "-" to the amps negative, does not matter which one on the amp (single channel for bass, no bridging)
          Closing SOON!
          Thanks for 10 years of fun!
          • jasonsnoddy
            • 1900
            question: its a 5 channel, but since im only having the sub right now i have it on 2 channel. is that incorrect?
            with a coathanger
            • IminDiegoTriick
              • Oct 2009
              • 1564
              check resistance on the terminals with a voltameter as well maybe.
              I'm so gone ✗ ♥ O
              • jasonsnoddy
                • 1900
                yup, apparently it was supposed to be on the 5 channel.
                thanks guys. i feel st00pid.
                with a coathanger
