how to open up the fuse box (not the clear cover)
  • mr.vang
    • 4371
    I'm trying to open my 318 fuse box because i need to check under fuse 21. also before checking fuse 21 the previous owner replace it with a different fuse number 10. it was suppose to be fuse 7.5, can that cause any problem?
  • HarryPotter
    • Jan 2010
    • 3642
    Isn't this the A/c fuse? I believe there is a screw that holds the top panel to the box. It should come off relatively easy. I had to do this to the same fuse and soder a wire underneath of it because I couldn't get a steady 12v's at the fuse connection.
    John F. Kennedy
    • mr.vang
      • 4371
      yeah there were two screw. i unscrew them and still didn't budge so i give up cause i don't want to break anything.:???:
      • Doughnut
        • Oct 2007
        • 869
        After this comment, IMO, you should take your car to an auto electrician.
        Save yourself the possible trouble.
        ///Monstrosity. (OO≡≡[][]≡≡OO)
        Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
