What goes here?
  • McGyver
    • 4636
    What goes here?
    I found these 2 plugs that arent connected to anything and im pretty sure they are the reason for all the redneck wireing in my car. What do the plugs in the red and green circles connect to? we'll call them left, middle, and right. i think the right is on a different harness and should plug into the premium amp right?
  • ak-
    • 12422
    Do you have an after-market antenna?
    1991 325iS turbo
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      please post a pic of said plugs, then i may be able to help you
      kthnxbai
      -Andy
      • McGyver
        • 4636
        nope. then antenna is oem and plugged into the oem stuff.
        • McGyver
          • 4636
          bump cuz im impatient.
          • dashboardmonkey
            FUCK YOUR WAFFLES
            • Jun 2008
            • 6158
            those plugs look like the plugs for the check panel module
            -Andy
            • CabrioPunk
              • 1451
              Yup. Lamp control module. Driver side, trunk.
              This is what those plug in to:
              Got check lights?
              • McGyver
                • 4636
                ^and how! bingo 2 ways. so would not having that fuck up tail light operation?
                • CabrioPunk
                  • 1451
                  That would cease all taillight operation AFAIK. I'm just the new guy here. But I have been reading up archived threads like a forum n00b should.
                  I have an extra one on hand intended for troubleshooting my check panel marking up my brake light as out. When my headlights are on tails, brakes and tag light all mark up on the check panel.
                  • McGyver
                    • 4636
                    im about to try to find the part numbers on realoem, but would that module from an '87 325is work in a '91 325i? (non-airbag into airbag car)
                    according to realoem:
                    '87 325is #1
                    http://www.realoem.com/bmw/showparts...28&hg=61&fg=25
                    '91 325i #13
                    http://www.realoem.com/bmw/showparts...38&hg=61&fg=25
                    the part numbers match unless im doing it wrong. so they would be interchangeable cuz its just for checking bulbs right?
                    • CabrioPunk
                      • 1451
                      That I don't know. I have a non-airbag. Part number on the swap one I have isn't showing up when I search pelican parts and I just put it back into the e30's trunk of parts.
                      It reads: Lampenkontrollergerat. 1 375 909.
                      Quick search of the forums I think a few are available for cheap if no parts car near-by.
